I replaced the front brake hoses on My '54 Buick and bled those 2 wheels. Took it for a road test and they still seem "spongy", had to push pedal down halfway and took extra distance to get to whoa up. Do I need to go ahead and bleed the rear wheels now as well?
Yes.............. well, maybe. How was the pedal before you changed the hoses? If full pedal, then there is still air in there somewhere. When you bleed them, you need to open the line several times to be sure you get all the air displaced. Be SURE to keep an eye on the level of fluid in the master cylinder so you don't inadvertently start pumping more air into the lines. Ray
I sucked mine through, when I was having the same problem. Used a big syringe, put a 1/4" rubber hose on it and onto the brake nipple, and drew fluid through all the way from the MC. Nobody was more surprised than me that it worked. This is the sort of crap you have top do when you are a billy-no-mates.
I usually put a vacuum line on the bleeder screw and place the other end in a partial container of brake fluid. Open the bleeder and pump the brakes a few times; purges the air out and prevents it from being sucked back in.
Single master, bleed everything and make sure the brake shoes are adjusted properly. This makes a big difference in a good high pedal... or not.
