Could I see some pics of what you guys use around the pedal levers passing thru the carpet. My carpeting was done before I had the pedals in place and my upholsterer has moved. Are there any nice rubber seals or something. I have expensive Square weave wool carpet and I want it to look good. Thanks for your help
Most often the trimmer uses a piece of matching upholstery material and sews it to the inside of the hole. I'm also interested to see what gets shown as a drop in. Makes me think of the piece made for the Dimmer switch but I have never seen anything like that big enough for the pedal arms.
Check this compilation of Google searches. When you click on one, it features it, and then you can click on the link under the photo to get to the seller. If I figured out how to work it, you surely can. https://www.google.com/search?rlz=1...AhWNKM0KHQctCOIQjJkEegQIBBAB&biw=1600&bih=757
That's a grate web sight. I'm going to order a pair of 37-38 Chrysler ones and see how they work on my F-100 pedals
Thanks for the help the google site was great I need slots The rubber I can find I need trim rings for the carpet and will make them if need be I made the trim rings for the shifter and e brake
My upholsterer trimmed the holes with the leather he used to bind the carpet. This isnt the best shot but I am at work right now (cant you tell?)
^^^^^^^ yep what Jeff J said, best deal out there 4 sure almost air tight if installed the right way.
