Technical Boxed Rods
Discussion in 'The Hokey Ass Message Board' started by butch, Nov 24, 2016.
Tags:
  1. butch
    butch
    from Michigan
    I would like some info on boxed rods. Did they fill up beam with welding rod ? Or cut a pice of steel to fit and weld it in. Must have been real heavy. Hard to imagine something like that nowadays. Picks would be cool.
  2. falcongeorge
    falcongeorge
    from BC
    Cut a piece of flat steel and welded it in. I have also seen some that had a rod welded in the center of the I-beam from the big end to the small end, I would think that that did very little other than add weight.
    RICH B likes this.
  3. mgtstumpy
    mgtstumpy
    All I know is that they were boxed like a frame to strengthen them. Primitive by today's standards however they were experimenting and leading the charge to go faster..
    s55mercury66, RICH B and Max Gearhead like this.
  4. D.N.D.
    D.N.D.
    That's all there was till Fred Carrilo came along with his H beam machined rod, Freds rods were a work of art !!!
    Used them for years and always spot on the money
    DND
    Speedwrench, Baron and mad mikey like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Man, haven't heard that term in years. Had forgot they did that.
  6. khead47
    khead47
    I once seen some rods beefed up with rebar! No shit!
  7. i suppose you would have to straighten and resize both ends , and then add some weight to the crankshaft to balance it?
  8. aaggie
    aaggie
    In 1961 I worked in a speed shop and we were bending rods in our Hemi dragster. The owner tried a set of Aluminum rods but they only lasted a few runs before stretching so he had a welder TIG boxing plates on some used stock rods and had it balanced. That engine lasted most of the season. Price wise the stuff from Callies, Eagle and others are a bargain today.
  9. falcongeorge
    falcongeorge
    from BC
    I have seen that too!
    Heres a pic of a rod with a piece of square rod welded in the center of the beam. The actual boxed rods were supposedly pretty strong, but heavy. I will try to find a pic.
  10. mgtstumpy
    mgtstumpy
