Bouncey straight axle front end...
Discussion in 'The Hokey Ass Message Board' started by awsomeears, Jan 14, 2014.
  1. awsomeears
    awsomeears
    Last year I received some incredible information from you guys, just by pictures you were pointing out what is going wrong, long story short I took it to a fab shop and in a few days Ron fixed all of it.
    Here was the original link http://www.jalopyjournal.com/forum/showthread.php?t=720800
    Now I'm 100% happy with his work, but now I'm asking for some more incite from the straight axle guys. It could be possible I'm expecting a Cadillac ride :p
    While driving my front end will get into a bouncing mode, similar to a pogo stick, up and down up and down. The car is not hard to handle left or right or power steers just the up and down motion.
    I started to think, could it be my leaf springs are to stiff and not letting my shocks actually dampen and slow the bounce down, I ended up placing ZIP TIES on my shocks and drove around for a bit and found the compression is about 3/4" of an inch travel.
    Its winter here in Wisconsin and before I stored the car I really should have removed the shocks and see how it handled, to prove if the shocks did anything at all for rebound.
    The shocks appear to be speedway shorty's...
    Any thoughts would be great, if more info or pictures are needed please let me know
    - Brad -
    * UPDATE * 1/15/14
    Here are the pictures I should have posted right away :rolleyes:
    The leaf width is 1 5/8 and the leaf spring length eye to eye is 26 1/2 in length. The Front Leaf Spring Axle Pad and U-bolts are new and bought from speedway.
    [​IMG] You can see the zip tie, that is the Total Travel from a drive around town
  2. BJR
    BJR
    Too stiff a spring will make a car bouncy. Look at an unloaded trailer, it bounces at every little bump. That's because with nothing in it the springs are too stiff. Put a load in it and the trailer ride smoothes right out. Since you cannot put more weight on the spring, you need to remove leaves or get spring with less weight caring capacity.
  3. squirrel
    How about some pictures of how the suspension looks now? like the shock, spring, shackles, etc. Might need to remove a wheel to get a good look at it for us. And several pics from different angles, side view, 45 degrees, front view, etc.
  4. gimpyshotrods
    gimpyshotrods
    Leaf springs are too stiff, shocks have insufficient dampening capability, or both.
  5. awsomeears
    awsomeears
    I should have really taken pictures and then posted this :cool: I will snap some pictures tomorrow.
    In my 1st post of the old thread the leaf springs are the same, but I don't want to post that picture to get everyone confused. The same shocks were used but now are welded up and down and not on that radical angle.
    The leaf springs have 3 separate springs total, tomorrow I will get measurements as well
    Thanks...
  6. Check your tires for any issues and roundness.
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    Without pictures we are flying blind. Post up lots of them from different angles so we can get a good idea what you have there.
    Don
  8. gimpyshotrods
    gimpyshotrods
    There are a bunch of pictures in his original thread. Just the shocks have been moved.
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    The one thing I see that might be a problem is the shortness of those springs. Longer springs allow the front end to ride better. Glad you changed the angle of those shocks, they were really not doing a thing the way they were.
    Don
  10. doinbad
    doinbad
    from celina tn
    Those look like trailer springs! i bought a model a took spring off cause it looked to short,they didnt even take trailer spring sticker off the top!
  11. SBCWelder
    SBCWelder
    I'm certainly no chassis expert, but the upper eyelet of the shock being turned that way may be causing a binding issue as well with the shock at that much of an angle
  12. James Curl
    James Curl
    If your shackles are too short they cannot allow enough travel for the increased length of the spring as it is compressed. Once the shackle is parallel to the centerline between the solid frame attachment point and the shackle attaching bushing the spring is stopped from any upward travel by the distance between attaching points that is shorter than the spring is when placed under load and the arch reduced.
  13. squirrel
    That's what my guess is....springs have way too much rate, because they are too short, and the leaves are too thick.
    The springs I put on mine run the entire length of the front subframe....
  14. Blue One
    Blue One
    from Alberta
    If you bothered to read anything before you posted, you would have seen that the shocks have been changed to a different angle and are now straight up :rolleyes:
  15. Judd
    Judd
    My Comet had this problem and I cured it by removing one leaf on each side.
  16. 1971BB427
    1971BB427
    from Oregon
    Too much spring, and the trailer springs will be tougher to adjust with the thick minimal number of springs used. I'd take the longest spring after the main out. If that doesn't do it, then take another.
  17. Rework your shock mount,,it can't possibly be doing the job,,it needs to be straight up with the short springs.
    Something similar to this. HRP
  18. One thing to consider and is going to make me very unpopular is that you are using speedway shocks of questionable quality. Try a name brand shock like a Monroe or ???, a gas shock or notrogen cell shock is a good idea. hell just to make me more unpopular when I was driving mud trucks I liked Ranchos. :eek:
    There is always the possibility that your springs are too stiff, that is common across the board here. Everything from A coupes to surf vans have too much spring. No way to know that without knowing the rping rate and the front end weight, but you could try removing a leaf andf seeing if you get any change, if so work with the local spring shop to build the proper rate spring for your car.
  19. http://www.jalopyjournal.com/forum/showthread.php?t=202296
    Here's some more spring rate calculator stuff.
    Just guessing that the spring is 1.75 x 0.38 x 26 x 3 leafs and that's about 1000lb spring each up front. Also that's about the smallest cheapest trailer springs available. About 20.00 each.
  20. gimpyshotrods
    gimpyshotrods
    I'd like to see a spring with more, thinner leaves, about twice the overall length of this spring, with shackles about twice as long, too.
    And yeah, those appear to be springs designed for a 2000lb. trailer axle.
    And ol'Beaner is correct. Speedway shocks are mediocre, at best. Spend the money on good shocks.
  21. 34toddster
    34toddster
    from Missouri
    What's up with the front shackle does it go forward when weight is applied?
  22. SBCWelder
    SBCWelder
    Sorry, I didn't read 8 pages of a thread before posting. Saw the picture with the angled shocks and assumed it was the current setup.
    If that issue has been corrected, then that leaves spring rate and shackle angle which have both been addressed by other posters.
  23. DICK SPADARO
    DICK SPADARO
    Bouncey or just rough ride when you hit the expansion joints. I'm with other that think those are trailer springs, what is the load rate on those. Here is a quick backyard way to determine the spring size range you should be in--- Approximate front total load divided by 2 = spring load. So if the front end of your car weighs 1000 lbs/2 = 500 per wheel.. then / suspension travel- say 2" = 250lb spring
  24. Blue One
    Blue One
    from Alberta
    That's ok, sometimes details are easy to miss. The shocks being changed is mentioned on post 5 of this thread, not buried 8 pages back. :)
  25. Very few actually read here!! It's comical almost.
    I guarantee I read 10-20 times the amount I post.
  26. Pete1
    Pete1
    from Wa.
    If you decide to get rid of the cheap shocks, get some that are designed to mount BODY UP.
    Anything you can do to reduce unsprung weight helps.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    . Bounce on a straight axle can be induced by : out of round tires/ rims ,front OR rear ,bad shocks, wrong springs , toe-in/out, tire pressure, just to name a few .
    dave
  28. SBCWelder
    SBCWelder
    Yep. Everything is spelled out clear as mud.
    I'm guilty of skimming over posts and picking out what I feel are the important bits. Obviously I missed an important detail this time around. I'll sit back and wait for the solution to be posted...
  29. tjet
    tjet
    1. Early Hemi Tech
    Try adding some caster shims. Napa sells 3 degree & 6 degree shims. It sounds like it's progressive (it gets worse if unchecked - like a speed or load change).
    Sometimes all it takes to break a dynamic oscillation is to make a change in the force direction.
