Projects Bought this pipe bender for $275
Discussion in 'The Hokey Ass Message Board' started by Fstarocka, Jan 27, 2021.
  1. Fstarocka
    Fstarocka
    Saw this on a pallet and it powers on and works well, not quite sure how to use it?
  2. oldiron 440
    oldiron 440
    It seams like that would make long bends, think spiral staircase.
    warhorseracing and X38 like this.
  3. vtx1800
    vtx1800
    I am jealous.
    juan motime likes this.
  4. mlagusis
    mlagusis
    Tubing roller. Still cool and a great buy for what you paid.
  5. Marty Strode
    Marty Strode
    It's not really a bender, but a roller, looks like a heavy duty unit. It will produce bends similar to this. IMG_1208.JPG IMG_1212.JPG
    dana barlow, Cosmo49, X38 and 5 others like this.
  6. cool....search for a manual on Evil bay....
  7. Fstarocka
    Fstarocka
    ok - will do.. There is a 3rd wheel that goes on the center pin (its not on in the pics), thought I might be able to make some tighter bends for exhaust possibly, maybe it can be modified?
    I wouldnt even know how to use it- whats the Handle for at the top, and does it roll the tube thru or just press?
    2mm = 0.078 max wall thickness, exhaust is around 65 thou. I bought it more on a whim - im sure in time ill figure out what can be done with it :)
  8. Fstarocka
    Fstarocka
  9. Mr48chev
    It looks like this is what you have Electric Pipe Tube Bender With 9 Round And 8 Square Die Set (5/8"-3") – Vevor US
    A bit of requesting can probably get the manuals for it.
    UPDATE: it looks like you were looking at the same time. It may be sold by several brands by the looks of it. Handy if you need it, worth more than you paid if you decide you don't. You may end up making yard furniture for your significant other if they find out what it will do though.
    VANDENPLAS and kidcampbell71 like this.
  10. nochop
    nochop
    from norcal
    Greenlee conduit bender I think. For electrical conduit I think
    Elcohaulic likes this.
  11. Fortunateson
    Fortunateson
    Too bad it isn't the fully enclosed one because that one is, "more safe" and will "live a longer life"!
  12. stanlow69
    stanlow69
    Also puts a slight crown on tubing for like pick up bed covers and boat tops.
  13. Happydaze
    Happydaze
    Nice find and will come in very useful, but you'll quickly find it won't help with exhausts. Great way of creating a pile of scrap material if you were to try. Now there's a challenge for you! ha ha
    Chris
    fegsta and VANDENPLAS like this.
  14. Budget36
    Budget36
    I’d have bought it too for that price. I’m odd like that;)
    kidcampbell71 likes this.
  15. COCONUTS
    COCONUTS
    Put it on a small trailer along with a generator and take it to car shows. Oh yea, you might want to bend up a bunch of pipe first, just to get the hang of it. Could be a small money maker, well maybe. I saw a guy once with a louver press on a small trailer doing the same thing.
  16. lake_harley
    lake_harley
    It turns in both directions. Tube goes on top of the outer rollers and below the center roller. As you go forward and backward you increase the down pressure on the center wheel (mandrel) by turning the handle on top. As you increase the down pressure it continues to tighten the radius of the bend. I might be wrong, but I doubt it would do tight enough bends of a good quality on thin tubing for exhaust pipe. Nice purchase though!
    Lynn
  17. Need a grinder to go along with it? I'll hook you up brother!! I've got a bench model for sale ;) 20210128_083718.jpg
    Magfiend, fauj, Blues4U and 8 others like this.
  18. Curt Six
    Curt Six
    That's funny right there.
    jimmy six likes this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    We had a couple of Tauring roll benders where I worked. One was CNC. We mostly used them to form tubing into about a 20 foot diameter ring (multiple pcs). It will do some tighter stuff but probably not as tight as you need for exhaust
    TrailerTrashToo likes this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    anybody want to build one?
  21. 51504bat
    51504bat
    Like the OSHA approved double lock nuts on the spindle.:cool:
    Lloyd's paint & glass likes this.
  22. 1934coupe
    1934coupe
    I don't want to burst any bubbles but I believe it is a "bender" just like a exhaust pipe bender. You would be hard pressed to pull and push tubing or pipe through that. It's intended use is to exert force in the vertical direction. Unless those side rollers are powered I can't see how you will move the pipe foward and backward. I say this because I have a Greenlee tubing bender and the main radius die captures the tubing as you apply pressure to the ram, it is eccentric and causes the tubing to be pulled along the die. Like a exhaust pipe bender that one will tend to crush the tubing.
    Pat
  23. They are driven. Hence the motor on the bottom.
    Sent from my SM-G950W using The H.A.M.B. mobile app
  24. 1934coupe
    1934coupe
    K13 I stand corrected, nice score.
    Pat
  25. lostone
    lostone
    from kansas
    Yep motor driven.
    This is a tubing "roller" not actually a tubing bender.
    This would be good for making those circular frame yard swings.
    Agree not worth much to bend exhaust pipe...
  26. Fstarocka
    Fstarocka
    Well I do own a boat repair shop.. maybe try bend some of the Ss rails etc..
    I saw some videos on how to use it, this supposedly bends up to 76mm 80 thou wall..
    I see depending on dies it can do angle iron, flat and square bar too..
  27. Not a conduit bender, wrong kind of shoes.
    Moriarity likes this.
  28. I hope I didn't come across as being snotty. I was just typing a quick response on my phone and didn't mean it to sound condescending.
  29. Fortunateson
    Fortunateson
    I suppose you could use it to build an industrial level still!
  30. nochop
    nochop
    from norcal
    I’m no sparky....me poo pusher, retired
