Projects Bonneville XF/GMR Build
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Sep 14, 2021.
  1. cornfieldcustoms
    cornfieldcustoms
    i land speed racing light weight is not a concern. You want to be a little on the heavy side. I did it more for detail than anything
  2. There are some roadsters in the 3000# range and some doorslammers upwards of 5000
    Stogy, alanp561 and loudbang like this.
  3. NoSurf
    NoSurf
    Amazing work.
    Thank you for taking the time to post up the progress pics.
    Could you show and explain how you are mounting the fiberglass body?
    Stogy, Tman, alanp561 and 1 other person like this.
  4. cornfieldcustoms
    cornfieldcustoms
    It will be mounted with 6 Dzus fasteners so the body can be be removed easily to work on the car
    loudbang, Stogy, Tman and 1 other person like this.
  5. ronnieroadster
    ronnieroadster
    Very nice work overall the car looks pretty slippery looking forward to seeing it in person in the future.
    Ronnieroadster
    loudbang, Stogy and Tman like this.
  6. cornfieldcustoms
    cornfieldcustoms
    Thanks
    Stogy and loudbang like this.
  7. loudbang
    Thanks for keeping us HAMBERS that do not have any of the other social media in mind and posting your fine work here. :)
    Stogy and The Magic Ratchet like this.
  8. cornfieldcustoms
    cornfieldcustoms
    Got the hood blister trimmed, but welded and mostly worked in. Weld seam Still needs to be metal finished. Had a buddy sit in the car since i havent seen anyone in with the tonneau and windscreen on it. He is a little taller than me in the torso so the helmet is higher in the cage on him than it will be for me. 5A6AA73A-1E02-48C1-8148-B15975E54372.jpeg 839E4FC8-09B7-42FD-86C6-E2C53B58C6BE.jpeg 65E91A73-052B-45BA-9467-FFFE066F950C.jpeg 742DB41C-B930-4F19-BD7D-B014611DDCFF.jpeg 90539597-2420-4CFF-8BAF-6BB00F1F7F07.jpeg 3F4FE64A-2A01-4DA2-B446-847F45F9509C.jpeg 1B8DCDD2-5FD9-49DB-AE1E-F04A5C1F0003.jpeg
  9. AmishMike
    AmishMike
    SWEET!!!
    loudbang and Stogy like this.
  10. 28rpu
    28rpu
    You're doing a great job!
  11. cornfieldcustoms
    cornfieldcustoms
    thank you
  12. cornfieldcustoms
    cornfieldcustoms
    Some updates. Welding up the tonneau covers and adding Dzus fasteners, fuel vent/ roll over vent done. Started on belly pans, splitter, and crank case vacuum system. More fuel lines ran, and started building the fire doors for the hood sides. Slowly
    But surely its getting there F9D44B7B-6767-4944-AD60-589C9B4944B2.jpeg 6E785DF0-833E-467B-9F8B-8794AE08237C.jpeg D359B802-4932-4684-AB86-B5A72CDB0F71.jpeg E3067EB7-3ECD-4EF4-BAB6-A5A090005E69.jpeg E1F9EEBB-AE49-4A68-8986-807A96359E23.jpeg 3466CF45-B01E-4F07-A549-19AAD99880C9.jpeg 1F21B28D-A78B-41CF-8777-74205B177FCA.jpeg 26D8C38D-24A5-4756-99E8-E5280004DDF7.jpeg 63A779D3-252A-4FE1-962C-0608E7CFDB06.jpeg 8AE64245-CD7D-44B7-B590-DE4BB2F0089D.jpeg CFC29011-3D45-425D-9B2E-45B2B2A389D7.jpeg 13561947-8294-4277-8AE7-A0F48E37149C.jpeg BE21A8DB-798A-4652-8FC9-F7F6E5707A5E.jpeg 4516EC9E-A01B-40D6-8C61-D9600FE74291.jpeg 67B6E4CF-AF0D-4F14-90ED-8DD12BDC9BDC.jpeg 574FF737-65EF-4955-A499-231044FAE7B7.jpeg EA9FB4E0-398C-440F-956B-635287B74A2E.jpeg 286BEB1C-AB3C-4C1F-94FE-9AA8C8B84276.jpeg 2F8746AB-FD2D-4C57-A057-918ED72C80DB.jpeg F9A9A6E7-94B4-445C-9D96-11021688EA6F.jpeg
  13. Stogy
    Stogy
    That's truly aircraft inspired, all of it...even if not the real deal and I'm sure much of it is right from the AC express...love it...and that is truly Traditional...wow your workmanship is awe inspiring...
    loudbang and AmishMike like this.
  14. Have you run your fire doors by Roy Creel?
    loudbang, gas pumper and Stogy like this.
  15. Beautiful work! What gauge and grade of aluminum sheet metal are you using?
  16. cornfieldcustoms
    cornfieldcustoms
    No i have not. They are not required in my class but i wanted them just in case.
  17. cornfieldcustoms
    cornfieldcustoms
    .063 3003-H-14
    loudbang, Stogy and El Hueso like this.
  18. I am asking because all I have seen are just spring loaded. Love those latches, using them on our canopy
  19. cornfieldcustoms
    cornfieldcustoms
    The one good thing is these are spring loaded but open out. You push the button and they pop open
  20. Stogy
    Stogy
    Those are good to 600mph...I installed them on many parts over the years...some of these AC designs are basically unchanged from their early introductions back in the day...
  21. I know, I have several of them. But if that car is on fire do you want to touch that button or simply push your fire extinguisher through a spring loaded hatch? The Safety crew is very experienced, I have trust in them. But, I asked because I do not know the answer. The ruling for Special Construction cars came out in 2017. Details are not laid out in the rulebook. A good idea for any car really.
  22. Stogy
    Stogy
    All for safety @Tman just romanticizing about my good Ole days around aircraft and knowing what happened to Hotrod after WW11...
    It'd be interesting to know how many clecos I've installed and removed in my 40 plus years...those are #30s all around that canopy...oh the memories...
    loudbang and Tman like this.
  23. cornfieldcustoms
    cornfieldcustoms
    I feel ya. Seems my daily life consists if installing and removing clecos lol
    loudbang, Tman and Stogy like this.
  24. cornfieldcustoms
    cornfieldcustoms
    Working on getting the firefox fire suppression system in the car, and other stuff checked off the list. Volt gauge finally showed up so got that in, getting the nose mounted and splitter finished up. CAA67656-6B51-4F60-AABC-AC64BE5E532C.jpeg 130C08A5-4B89-4EF6-B8EA-67257D29F1E0.jpeg 4135E188-36E3-498B-B0AF-7432B8B56E48.jpeg B5C8C2BB-EF58-439B-B9D9-34BA765BEBCF.jpeg EF92F4DF-0DF8-4FC1-B148-8E05FC6AE3D1.jpeg 1875F81A-5A8D-4572-9F7F-4A01C92AE5FB.jpeg B7744968-0AD8-4187-B417-CE44C8D17898.jpeg 00606E73-EF2D-43EC-96FB-140126FE24A3.jpeg
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  26. cornfieldcustoms
    cornfieldcustoms
    Thanks
  27. cornfieldcustoms
    cornfieldcustoms
    Started working on the headers today. One down one to go 4B909BDC-B564-45E0-8837-5B3236AB8526.jpeg 2DF0498A-7543-43DF-BBF9-9953299A34C7.jpeg B2F41F2C-E948-415A-9748-7ACF10BD0FFE.jpeg BF81416A-4C4D-4B0E-A8BD-2D9776BCA6FD.jpeg 5E91E3E7-3571-4787-AE05-A3960AD3659D.jpeg 2C568D92-D3BA-4334-8513-5CAA56EAA890.jpeg DAEA7A4E-2E78-4D5C-AE3D-4A743B15E5BE.jpeg 14AAABCB-A4A3-4A01-AD61-E9E649DF772A.jpeg DD562F12-6D70-401F-9FAC-714CB6BCE441.jpeg
  28. AmishMike
    AmishMike
    If your speed matches the meticulous beautiful build, should go 400+
  29. spanners
    spanners
    Looks fast standing still. Beautiful workmanship.
  30. ronnieroadster
    ronnieroadster
    Question the electric fuel injectors is this for testing only?
    Stogy likes this.
