Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. What a beaut in bare metal! The car's gonna look so slick and sharp in paint though too. Can't wait to see the finished product.
    Whats the story on the old T floating around in some backgrounds of photos?
  2. hechtspeed
    hechtspeed
    Any progress on the '32 Chris?
  3. Salt Flats Speed Shop
    from Utah
    I hope this should be the last blocking session on the body. The last blocking session went well and almost everything blocked out perfect. I just had to touch up a couple areas and this should be the final blocking. Then its on to the doors, hood and grill. (Ive got one more cool modification on the hood to do that you guys will like).
    Here are some more shots. I sprayed the car last night.
  4. GaryB
    GaryB
    from Reno,nv
    looks real good with some color on it
  5. Salt Flats Speed Shop
    from Utah
    I got the doors, hood tops, and grill in primer last night. They are all pretty straight so it shouldnt take long to get them all blocked out.
  6. GaryB
    GaryB
    from Reno,nv
  7. lorodz
    lorodz
    Looking good
  8. Pewsplace
    Pewsplace
    Thanks for the update. Just be patience.... the economy is getting better and the bucks will come rolling in soon.
  9. hechtspeed
    hechtspeed
    So cool Chris! Keep us updated!
  10. Salt Flats Speed Shop
    from Utah
    I worked last night on fixing the firewall. The feet needed some pieces made where they mount, and the center of the firewall needed work where it fit around the engine. I had some original pieces that I spliced in. It only had a couple extra holes that I fixed. Now its ready for bodywork.
  11. Salt Flats Speed Shop
    from Utah
    I never really liked the look of the modern tie rods that I had on the end of the wishbones, and the steering rod. So my buddy Brent gave me some model a tie rod ends and a model a drag link. So I cut the ends off of the drag link and had them threaded to fit in the ends of my wishbones. Then I had to put in a new tapered plug that extended away from the frame a little bit so that the end of the tie rod wouldn't hit the frame. Now it looks so much better and more old school. Kind of looks like it just floats there on the end.
  12. -Brent-
    -Brent-
    That's very cool. Threading them is something I haven't seen done before.
  13. lowtruck
    lowtruck
    from Omaha
    I like the rod ends.
    Good to see this build back at the top. I love this car.
  14. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I'm going to go a head and steal that haha!! great work!
  15. Salt Flats Speed Shop
    from Utah
    Ya I really think they look so much better. And your more that welcome to use the idea. :)
  16. Salt Flats Speed Shop
    from Utah
    Tonight I got the front shocks mounted and the dogbones cut down to size. It really works well and with them mounted inside the frame looks really clean from the outside.
    Im also working on the rear shocks. The shock its self is mounted and the dogbone is cut down, I just need to make the bracket to mount it to the axle.
  17. chevydave1965
    chevydave1965
    from Iowa
    Nice sedan build. Looks sweet guys !
  18. jj mack
    jj mack
    I am doing a very similar shock setup on my truck using Armstrong shocks. How important do you think it is to have the shock arm parallel to the split wishbone? Or does the shaft from the shock need to be perpendicular to the Wishbone? Or does it matter?
    BTW...I really like your work!
    JJ
  19. Salt Flats Speed Shop
    from Utah
    The important thing I made sure of was that the dogbone link was straight up and down. That way when it is pushed up and pulled down its not wanting to twist it. Other than that I think you are fine to have the shock in another angle than the wishbones cause the only thing your dealing with is the up and down motion not any left to right, and the shock link has enough play to it that when one side lifts up it can move around accordingly.
  20. hiboy32
    hiboy32
    from Omaha, NE
    this is really looking good, thanks for sharing.
  21. I agree, wish I had though of it!
  22. CTaulbert
    CTaulbert
    from Detroit
    I'm running a similar setup for the front wishbone/tierod end. For mine, I have some internally threaded (11/16-24) 28-34 tierod ends. I drew up a bung, and had a buddy machine them for me. I picked up some of those tapered 7 deg bungs from Speedway for the frame, but those were too deep - hardly one tread on the nut would engage. I ended up using some 7 deg tapered pieces from spindles that had the steering arms cut off.
    Anyway - here's the setup. If anyone is interested in the drawing for the wishbone bung, let me know.
  23. jj mack
    jj mack
    Thanks!
    Its not the first thing that I have OVERthunk!
  24. 29ToyA
    29ToyA
  25. Marten
    Marten
    Updates..Yummie! Thanks!
  26. Salt Flats Speed Shop
    from Utah
    I got an tachometer from a flathead guy in Washington. I'm curious to see if you guys have any info on it.
  27. racemad55
    racemad55
    Post flathead era!
  28. FINKSTR
    FINKSTR
    Thanks for the update! It's been a great built since day one. It gives me insentive to get my butt out in the shop and work on my tudor.
  29. spike38
    spike38
    Yes! Like he says :)
    Spike:D
  30. Minewithnoshine
    Minewithnoshine
    Looking awesome Chris!
