Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. pompadour
    pompadour
    Thanks...Also how much caster are you running?
  2. Salt Flats Speed Shop
    from Utah
    I set mine so at ride height its at 7 degrees.
  3. Chris13
    Chris13
    from England.
    Wow!
    The sedan looks the nuts.
    Chop is just right and all those louvres makes it,well,stunning!
    Fantastic work. ;)
  4. PoPo
    PoPo
    makes me not want to drop my 32 heavy axle at all!!! Looks great man
  5. Patrick46
    Patrick46
    Yea...like THAT's gonna be a problem for you! :rolleyes:
    Bitchin work guy!
  6. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    This is a great picture, that insert looks amazing filled with all those louvers.
  7. DaRatt13
    DaRatt13
    from SoCal
    Great lookin project! I like the 51/2 & 31/2 with the roof work done.
  8. This is an AWESOME build! JUST PLAIN BAD ASS!! I love hammered 32 tudors but this one is going to a whole new level! cw.
  9. IronFord
    IronFord
    from NoDak
    I thought I knew how I wanted to build my 32 sedan till I saw this build. Very nice work
  10. rodncustom
    rodncustom
    So what is the plan for this car...keeper?
  11. Salt Flats Speed Shop
    from Utah
    Ya its going to be my advertisement car. Ill put Salt Flats Speed Shop above the drip rails, and a Bonneville number on the door.
    Of course everything is for sale for the right price. Id hate to see her ever go, but i'd just build another :)
  12. Salt Flats Speed Shop
    from Utah
    Ive been working on the floor in the car. Ive got my pedals ordered so I can figure out the front area. Then tonight I started trimming the rear floor to have clearance for the rear end. Ill probably go ahead now and get a quick-change so I can get a drive-line and know how to finish up the floor.
    Also trimmed off the rear frame horns. Not sure if I am going to bob them up to the body and run a bar across, or leave them off completely. If anything I want to build a bolt in cross-member that has a tailor hitch so I can haul stuff.
  13. patman
    patman
    OK, it's official...I hate you.
    :D:D
  14. KENDEUCE
    KENDEUCE
    They just ran a picture of the aluminum Willys in The Rodders Journal #47. Congratulations!! TOO COOL.
  15. what quick change do you think you will go with?
  16. Salt Flats Speed Shop
    from Utah
    Im going to get a Rodsville unit. Then find an original cover to replace the Rodsville one. Ive looked around and for the piece of mind knowing its all new and better material. I just cant go any other way.
  17. Salt Flats Speed Shop
    from Utah
    I thought I would move the car into the middle of the shop. Get a good look at it without the huge hoist underneath it.
  18. hiboy32
    hiboy32
    from Omaha, NE
    That is badass! thank you for the updated shots. killer car
  19. -Brent-
    -Brent-
    Looks fabulous, Chris! Knocked it out of the park.
  20. desertdroog
    desertdroog
    Thanks for giving me a new desktop image(s).
  21. Kreepea_1
    Kreepea_1
    Awesome! Like a moth to a flame, I'm drawn to good metal work.
  22. PASTDUEBILL
    PASTDUEBILL
    I'm one of the ones that gave you a hard time about the chop.
    I was wrong. The proportions are spot on.
  23. OoltewahSpeedShop
    OoltewahSpeedShop
    This might just be the perfect 32 sedan. Looks great, keep it up.
    Kevin
  24. coopsdaddy
    coopsdaddy
    from oklahoma
    How do you plan to fasten the top down?
  25. Salt Flats Speed Shop
    from Utah
    it will be bolted through the wood undernieth with some button head aluminum bolts.
  26. A super fine example of the Deuce Tudor.!!!
  27. jerseyboy
    jerseyboy
    Wowee! That is one damn fine car! It is always a pleasure to read your threads! One word, stance, stance, stance!:D:D:D:D:D:D:D:D:D:D:D:D:D:cool:
  28. 32 for me
    32 for me
    from SO. CAL.
    Your sedan is BITCH'N, I thought I would show you mine, similar.
  29. hellonwheels
    hellonwheels
    Will the heads be exposed on top? Have you ever seen threaded rivets? Restoration Supply Company sells em, pretty cool hardware. Their catalog is worth a look anyway, lots of obscure stuff perfect for hotrods...
    The sedan is looking awesome by the way, SICK, SICK, SICK!!!
  30. Salt Flats Speed Shop
    from Utah
    The ones I'm using have a small smooth button top, and then have a slot screw on the bottom.
    Thanks for your comments on the sedan. Glad you like it.
