Bones Question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Feb 27, 2013.
  1. harleycontracter
    harleycontracter
    I have a set of bones. Was told they were 1933 . One of the bosses that is around the axle is thicker than the other. 1933 ??????
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Only the 35-48 front wishbones have the thicker bosses on top to support the spring perches and the car.
  3. alchemy
    alchemy
    Clear pictures would probably get you a definitive answer.
  4. harleycontracter
    harleycontracter
    I'll take pics tonight. So the bones I have are junk ? Can't really be used with a 32 application. Now that I have it all together. Right?
  5. Ghost of ElMirage
    Ghost of ElMirage
    NO SOUP FOR YOU TILL PICTURES!:eek: Damn you're impatient nobody can answer anything wthout pix dude! :D
  6. So is it the top or bottom that is thicker? Oh yes the pics will help.
  7. rcavaliers
    rcavaliers
    from downey
    I like'em with a thicker bottom! mmm mmm
  8. Ghost of ElMirage
    Ghost of ElMirage
    Def thicker at the bottom. But he also has to think about the axle boss spacing. Is is 2inches or 2.25? And the thicker side down is going to ensure proper caster angle . Or at least point you in the right direction.
  9. harleycontracter
    harleycontracter
    I had the thicker boss on the bottom and the camber was in the wrong direction.I tried thicker boss on top just to see and it sits right .
    Bones obviously not 33 as I was told. Are they still usable? I've used harpins in the past.
  10. 117harv
    117harv
    35-36 wishbones, the thick part goes on top. These later bones are why your perch bolts were too short.
  11. harleycontracter
    harleycontracter
    Harv,
    Can I use them for what Im doing? You know what I'm building
  12. Yup 35-36 bones, 2" wide axle with hangers cut off. Same as the 32-34 bones but have the spring hangers cast in (They differ in overall length 32,33-34).
  13. metal man
    metal man
    That's right. And those bones will be fine on your car...nothing wrong with them at all.
    Ford went to the thicker top in '35 when they started hanging the spring out in front of the axle.
  14. harleycontracter
    harleycontracter
    Whewwwwwwww Thought I had another part to leave on the shelf. Thanks.............
  15. 296 V8
    296 V8
    from Nor~Cal
    You can shave them down and re taper the hole.
    Keep in mind
    35 and up wishbone is offset (at the axle end) for the tierod to go under … unlike 28 to 34 to run over.
  16. harleycontracter
    harleycontracter
    Could these be used in a 50's style build?
