Technical Bone stock 32
Discussion in 'Traditional Hot Rods' started by koolbeans, Oct 31, 2018.
  1. koolbeans
    koolbeans
    Can you put a 4" or 5" dropped axle in place of the original?
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  2. alchemy
    alchemy
    Not without other mods.
  3. Malcolm
    Malcolm
    from Nebraska
    If you do, you may as well upgrade to hydraulic brakes at the same time.
    lothiandon1940, Tim and loudbang like this.
  4. Deuce Lover
    Deuce Lover
    Won't work with mechanical brakes
    LOU WELLS likes this.
  5. adam401
    adam401
    You have to raise the brake actuators. You also have to bend the arms on the spindles.
    Raising the brake actuators on the spring perch bolts has been covered here before.
  6. nochop
    nochop
    from norcal
    Lots of work, you should sell it at a loss just to get rid of it pm me for my phone #
  7. Also watch for tire clearance. Any chance you could get enough drop by using a reversed eye spring and slightly smaller tires in the front? Also add your general location to your profile.
    Charlie Stephens
  8. koolbeans
    koolbeans
    You are hilarious.....
    OldBolts and nochop like this.
  9. koolbeans
    koolbeans
    Ok. Split wish bones. Doin juice. Maybe? Reverse spring. Without fenders ya think we could do a 5".
  10. Someone might correct me but I don't think you have to split the wishbones. How about some pictures? How about leaving it stock and updating the drivetrain (as I did with my AVATAR)?
    Charlie Stephens
  11. koolbeans
    koolbeans
    Here's the plan.
    So many highboys are conversions. Didn't realize such till I searched.
    So... remove the front fenders, take the axle/spring out. Split the wishbones, 4 or 5" drop axle, new spring, juice brakes, work out the steering and you are on your way...????
    grifcarnut likes this.
  12. flatford39
    flatford39
    You do not have to split the wishbones and if you don't you will have a better handling car. Trust Henry on this. You need to tell us more. What engine is in it? Is it staying in it or are you upgrading to something newer? What is the drive train?
    F-ONE and clem like this.
  13.
    heavydumper, clem and X38 like this.
  14. I thought you might be interested in the way I mounted my master cylinder. I use stock pedals and didn't have to drill any holes. Overhang is welded to a plate that was bolted to the K member.
  15. Once again, people are trying to help as the scraps of information from the OP come out piece by piece and the goal posts keep moving.:rolleyes:
  16. How about some pictures of how it looks and maybe one like you would like it to look?
    Charlie Stephens
  17. koolbeans
    koolbeans
    You highlighted conversions. While chasing in HAMB alone on average 60% of highboys, all Henry metal have been created from a full fendered car. Fished this twice with same results. I'ma not say this is bad or wrong, it is what it is.
    With this in mind and with today's goodies at everyone's finger tips it's pretty simple and easy to make a really nice highboy or custom full fendered car.
    I've scratch built a lot of hot rods back in the day. Now with the horn of plenty of components such allows no excuses for kool cars.
    That's where I'm heading with my initial questions asked.
  18. I'll be back when this thread is written in colloquial English
  19. koolbeans
    koolbeans
    That's kool. Certainly an event of the build.
  20. koolbeans
    koolbeans
    Well, plan?, is to plug and play with minimal welding to original frame.
  21. koolbeans
    koolbeans
    Will be disc all around.
  22. koolbeans
    koolbeans
    Will be disc/juice all around. Bad experience in '31 with mechanical and school bus rear end. Juice hence forth.
  23. koolbeans
    koolbeans
    Thanks. Will be highboy. Oh, what should be the axle face to face in the rear??
  24. koolbeans
    koolbeans
    Kinda sorta. No fenders. Hopefully a ground hugger. Ardun conversion with 200-r4, quick change rear.
  25. koolbeans
    koolbeans
    No fenders, dropped front, Ardun conversion, 200-r4, quick change, , discs, air/heat....
  26. koolbeans
    koolbeans
    Hurry back.....
  27. alchemy
    alchemy
    So basically you are gutting a stock 32. Nothing close to the original architecture if you are planning a Chevy automatic behind your Ardun. Doesn't really go at all with your original question.
    If you want people to take you seriously on the HAMB, we don't like to be played around with. Lots of HAMBers have great ideas, and even more have real-world experience. But it helps a ton if you give us the parameters in the original post. A wishy-washy concept, continually changing target, and unclear prose for the sake of (your attempt at) literary stardom just wastes our time. Not many guys will stick around to help with that. Especially for a newbie.
    HotrodHR, HEMI32, clunker and 14 others like this.
  28. town sedan
    town sedan
    Cash for an Ardun? Cool, just pick a shop tell them what you want, like you told us above above, and leave your wheelbarrow full of money, they'll call ya when it's ready. Enjoy.
    -Dave
  29. I wonder if you would be better off both cost wise and easy of build to use a steel Brookville roadster body, assuming it is going to be a roadster. Have you seen their roadster bodies.?
    Charlie Stephens
    town sedan likes this.
  30. oldolds
    oldolds
    Please give us a location, at least a country, so we can get an understanding of some of the things you are saying. You started out saying stock 32 now you are building a high dollar car. If you are going high dollar get a chassis built to do what you are doing. You sound like you want to build a nice car. Your choice of Ardun, 200r4, and A/C sound like you want to build a show winner, trailer queen street rod. Most guys here prefer driver hot rods! So be careful in your next choice of words. :confused::eek::D
