Technical Bonding Phenolic Resin Board
Discussion in 'The Hokey Ass Message Board' started by blue 49, Jan 2, 2015.
  1. blue 49
    blue 49
    from Iowa
    I have some 3/4" phenolic resin board I want to make a 1 1/2" carb spacer out of. Is there something I can bond and seal the 2 pieces together with so I don't have to use another gasket? I was thinking about roughing it up and using fiberglass resin. Will that work being exposed to gas? Thanks in advance.
    Blue
  2. Roadsir
    Roadsir
    I think that would hold up, but to be sure you might want to try some automotive 2 part epoxies like JB weld that clearly state they are fuel proof.
  3. nexxussian
    nexxussian
    I don't know if polyester resin (common fiberglass resin) will hold, some of the epoxies might, since you are bonding the phenolic to itself.
    If that doesn't work out, you could stack them up and use a layer of Permatex #3 "Aviation Form-A-Gasket" between each ply.
    From the Permatex site "Slow-drying, non-hardening brush-top sealant approved for use in aviation as well as automotive applications. Temperature range -65°F to 400°F (-54°C to 204°C); resists gasoline, oil and grease."
    I do not work for them or sell their product.
    Hnstray likes this.
  4. nexxussian
    nexxussian
    I've used JB weld on fabricated Hilborn setup.
    It doesn't seem to care about gasoline, racing or otherwise.
    I would recommend at least pinning, if not screwing the spacer together so it is less likely to delaminate when not installed.
    Make sure to clamp the lamination together when you bond it so it adheres properly.
    Hnstray likes this.
  5. indyjps
    indyjps
    Any concerns with phenolic resin board and the alcohol/additives in today's gas?
  6. Blue One
    Blue One
    from Alberta
  7. Alcohol won't hurt it and like has been mentioned use a 2 part epoxy to bond it. They kae a regular 2 part epoxy for the process (it was originally used in the electronics industry) but JB weld will work like a champ. Don't forget to clamp them while the resin is setting up.
  8. There are several types of phenolic resin boards. If you're using the type used in the electronic industry, it can be drilled & tapped. In addition to using a bonding agent (JB Weld, etc.), I'd suggest screwing the 2 pieces together using countersunk machine screws. The holes left behind could be filled with the same bonding agent and sanded smooth.
    I'm getting ready to use electronic grade phenolic to make adapters to adapt air cleaners to the stacks on Stromberg 97 Scott tops.
  9. Dick Stevens
    Dick Stevens
  10. saltflats
    saltflats
    from Missouri
    How about grooving it for a Oring
  11. True, but it's listed as very good for ethanol. It also has a fairly low heat tolerance in the 200 degree range. But it's a good starting point. By contacting Devcon, I'm sure they have a better bonding agent.
  12. The phenolic resin glues well with epoxy, scuff it with course sandpaper for the best bond. A few screws or bolts won't hurt, but I think the carb studs should do.
  13. Steve its overkill but when we are doing it we take a ball end mill or drill bit and make some dimples in the surface to be bonded.
  14. blue 49
    blue 49
    from Iowa
    The material I have is from a long gone tool and die shop. Sounds like J B Weld will be the way to go, just because it's the easiest to find. My plan is to have the top half a 4 hole and mill the divider between the primarys and secondarys on the lower half to make it a 2 hole. Going on a 2 plane intake. Thanks guys.
    Blue
  15. missysdad1
    missysdad1
    Go to your nearest gun shop and ask for AcraGlas - it's a 2-part product from Brownell's. It's a rifle bedding epoxy material that will bond just about anything to just about anything as long as it's wax, grease, teflon and oil free. It's easy to use and heat resistant in this application. I use it for just about everything and would use it for your task with no qualms whatever. It's great stuff!
  16. Grahamsc
    Grahamsc
    from Colorado
    This is what the custom knife guys use to make their own phenolic resin handle material. image.jpg
