Hot Rods Bomber Seat Build
Discussion in 'The Hokey Ass Message Board' started by Ratspit, Apr 24, 2019.
  1. Ratspit
    Ratspit
    I am in the process of building a 34 pickup and wanted a set of bomber seats. After looking around at what was on the market I decided to try my hand at building a set. The seats are loosely based of the Schick Johnson seat used in a P51 Mustang.
    First step was to sign up for a free trial of Autocad so that I could produce templates. After a bunch of mock ups I finally settled on a design and off the drawings went to be laser cut. I decided to use .065" aluminum which made for a very sturdy seat. Once I got them back all I needed to do was bend a few pieces, flare a few holes, and buck a whole lot of rivets. I still haven't decided on the edge detail. I'd like to match the channel that was used on the original seat but that will be really hard to bend. I might use a piece of round stock and slot it. It should be much easier to follow the curve of the sides.
    Here is a cost breakdown.
    Autocad - Free trial
    Laser cutting - $425 (which includes .065" 5056)
    Aluminum hat channel - $80 (eagle-aluminum.com) Part #3571
    Rivet Gun - $50 (Ebay, used)
    Tools - $30 Clecos, bucking bar, and rivet sets ( yardstore.com , used)
    Flaring punches - $200 Allstar 1.5" and 2.5"
    Rivets - $25 (aircraftspruce.com)
    If anyone is interested in the CAD drawings I'd be happy to forward them.
    20190123_171141_resized_1.jpg 20190316_152456_resized_1.jpg 20190316_152500_resized_1.jpg 20190316_152520_resized_1.jpg 20190319_180915_resized_1.jpg 20190320_174221_resized_1.jpg 20190320_174228_resized_1.jpg 20190320_174249_resized_1.jpg 20190330_115844_resized_1.jpg 20190330_115852_resized_1.jpg 20190422_071157_resized.jpg 20190422_071219_resized.jpg thumbnail_20190321_173953.jpg
    RICH B, bct, george cato and 7 others like this.
  2. Stogy
    Stogy
    Ain't that just the Bomb...er seats...:D...Really great job @Ratspit...you have to be pretty happy with those...;)
    So you have a bit of work still left to wrap them up but your making it look easy which it isn't...but yes not an uncommon item in postwar hotrods...
    That very nice of you to offer up things for others. I'd say you could produce those and sell them...I mean others do but you seem to have a knack for it.
    I look forward and I'm sure many others to your completed product. Are you making adjustable tracks?
    luckythirteenagogo and loudbang like this.
  3. Wow, that is well done. The thought of perfection comes to mind:D
    Stogy and loudbang like this.
  4. Ratspit
    Ratspit
    Yup, I definitely have a bit more work to finish up the seats. The plan is to do a faux patina finish to get a well used look, and make some canvas cushions. Fixed mounts to preserve as much head/leg room as possible.
  5. Bugguts
    Bugguts
    Those look great! Its a shame to cover up all that work with a pad, but more comfortable.
  6. rusty_bits
    rusty_bits
    Hello Ratspit, great job and I would be interested in the CAD drawings if you would not mind. regards
  7. Malcolm
    Malcolm
    from Nebraska
    Nice work! I don't recall the name of the product, but are you planning to apply the olive drab green finish and patina that?
  8. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Bullet holes.....?
  9. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    For a finish on my last 2 builds using Frank Wallic bomber seats I've painted them with 2 good coats of satin black Krylon and when really dry highlighted the edges and rivets with a fine scotch pad. Gave the entire seat a brushed finish with wear areas.
    Stogy likes this.
  10. Stogy
    Stogy
    @Ratspit, Aluminum technically needs (at least in aircraft) alodine before paint for corrosion and adhesion. I suppose many paints are formulated to do that...did you or are you planning that process...obviously Hotrods aren't airplanes but adhesion is important.
    Ever thought of polishing it?
    I was looking at a vintage Jalopy Racer yesterday that had an aviation seat in it. So yes they are an interesting period addition to vintage Hotrods that's a given.
  11. MrMike
    MrMike
    I as well, would be interested in a copy of the Cad drawings, thanks in advance.
    Stogy likes this.
  12. luckythirteenagogo
    luckythirteenagogo
    from Apex, NC
    Stogy likes this.
  13. Speed~On
    Speed~On
    Your seats look great, nice work.
  14. george cato
    george cato
    These look fantastic!
    I am definitely interested in the CAD file if ya got it!
  15. brady1929
    brady1929
    from Mesa, Az
    They look great. What are you going to do with the edges? I wish I knew how to make a "j" shaped piece of aluminum to rivet around the edge.
  16. Ratspit
    Ratspit
    I'd really like to match the patina on the original Schick-Johnson seat.
  17. Ratspit
    Ratspit
    A "J" shaped riveted edge would be perfect but I don't know how to bend it to follow the curves.
  18. Ratspit
    Ratspit
    I think a faux patina along the lines of either of these seats would be perfect bomber seat 1.jpg bomber seat 2.jpg
    Stogy likes this.
  19. Learned to rivet in the Navy. Wasn't much use where I was stationed. Only a/c was caused by sloppy ground crews. You've done a great job. Every time I see these seats I want to build a few myself. The pleasure of driving my neighbors crazy with a rivet gun would be worth the effort.
    Would also be pleased to have a set of the CAD drwgs.
    Thank you,
    Richard
  20. Very nice work! Add me to the list for a set of cad drawings. Thank you! Hobo Jim
    Stogy likes this.
  21. NICE JOB on the seats...….
    Wish I had a 2nd to go with my P51 seat that came in my 34 Ford P/U when I got it....
  22. Ratspit
    Ratspit
    Ok, now I'm truly jealous.
  23. flatheadgary
    flatheadgary
    from boron,ca
    you might look into making hammer form blocks for the edge part.
  24. boutlaw
    boutlaw
    Ratspit, excellent job, they look great....PM sent
