What is a good and safe way to mount a T coupe body to an A frame. Looks like the subframe on the body has 4 mounting points. Is this enough? What is a good rubber material to use for mounting and to prevent noise and vibration? Pic's, Resources? Can't find anything in search. thanks!
The T body,as well as A bodies, mounted to a set of oak wood mounting blocks cushioned with a woven belting(body to frame webbing) available at any old Ford parts supplier. You should have two mounting points at the cowl, rear edge of cowl at door opening, back of door post and at the tail. Of course the A frame does not configure to the T body but use original holes to go by.
