body mounts,no hockey pucks
Discussion in 'The Hokey Ass Message Board' started by anteek, Oct 8, 2012.
  1. anteek
    anteek
    Mounting a flat-floored body on an A chassis. Always used hockey pucks,can't get any cheap; what is a good alternative? What do you use?
  2. boat trailer rollers. cut them into "pucks".
    Also you could use the original webbing?
  3. Boones
    Boones
    from Kent, Wa
    webbing is what I thought was used from the factory on A chassis
  4. toreadorxlt
    toreadorxlt
    from Nashua, NH
    [​IMG] I made these for a few cars... The rubbers are energy suspension universal bodymount bushings. Work greats.
  5. Looks like my flathead mounts:D
  6. bustingear
    bustingear
    Don Rickles said everyone was a hockey puck
  7. Hackerbilt
    Hackerbilt
    I've used hockey pucks before, seemed to last.
    I tried to use boat trailer roller sections and the rubber split and became unstable in LESS than a year!
    Had to replace it all with proper rubber mounts the vehicle owner got somewhere else.
    Seemed very odd, then and now, that something meant to support a boat hull and also be exposed to sunlight in normal use would get bad so quick.
    Might have been cheap Chinese rubber I guess...but still I have to mention it so you can make an informed choice on what you use.
    Ultimately, the proper form of rubber mount intended for that usage is the correct thing to go with.
  8. fleetside66
    fleetside66
    Hockey pucks are that expensive? How many do you need?
  9. Blacktop Graffiti
    Blacktop Graffiti
    I've always wondered about hockey pucks as body bushings.
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    The autographed ones are pricey. :p
  11. Hackerbilt
    Hackerbilt
    The ones I used were autographed....Canadian Tire Ltd! Hahaha
    .99 cents each!!! :p:D
  12. outlaw256
    outlaw256
    you owe me a pack of cigarettes. i spit coke (a cola) all over the pack that was sittin in front of me!!!
  13. flying53gmc
    flying53gmc
    from M-boro, TN
    I cut pieces out of the sidewall of a radial tire. Hockey pucks seem too thick for many applications.
  14. 53sled
    53sled
    from KCMO
    hockey pucks are 12 for $24 on am-uh-zon
  15. VoodooTwin
    VoodooTwin
    from Noo Yawk
    You need to quit smoking anyway. :p
  16. Shane Spencer
    Shane Spencer
    hit your local ice rink. 99 cents a piece up here
  17. David Chandler
    David Chandler
    I've used them before on non Hamb applications. They work well. But don't over tighten them. They will split of you do.
  18. Case of 100 black regulation pucks for 109.99 shipped. Or 12 for 20.00 shipped on a quick Google search.
    blue, and yellow also available if you want different weights.
  19. That-there is a good idea too.
  20. hillbilly4008
    hillbilly4008
    from Rome NY
    I use pucks all the time. I warn you though, the soft training pucks they use for Mites do not make good motor mounts...
    But yeah, always less than a dollar for as long as I can remember. Better yet, walk around an ice rink. You'll find them under the bleachers, in dark filthy corners, stuck in nets...and guess what, dem ones dere are free, eh.
  21. dwaynerz
    dwaynerz
    op is from fla. not for certain, but im pretty sure hockey isnt big down that way :)
  22. hillbilly4008
    hillbilly4008
    from Rome NY
    they have ice hockey down there. When I played college hockey I had 2 team mates from Orlando, and 2 from Panama City. I also had a team mate from 'Bama. Then there were the Swedes and Norwegians, but they couldn't play worth a shit....riiiiiiiiight...haha
  23. Scarebird
    Scarebird
    Alliance Vendor
    from ABQ, USA
    "Rat Tricks" are though...
  24. Radical idea here, order a set of model A rubber body mounts for $6.25 at Mac's auto parts.
  25. Chevy Gasser
    Chevy Gasser
    How timely, just made some today. Some heavy rubber mat showed up. It is a heavy black, 1/2" thick matt some industrial work places used to stand/walk on. If I want round ones I just use a hole saw to cut the size I need. Heavy industrial belting can also be used, like the stuff they use to belt coal miles at a time.
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    Model As used wood blocks for body mounts. The body to frame webbing was laid on the rail and the blocks, aprons etc laid on it. The rubber pads were shims for door and panel alignment.
  27. plodge55aqua
    plodge55aqua
    from Alberta
    Henry J used the Rubber blocks with mesh in between .. something like old heavy Mudflap material from a 18 wheeler..
