Blown 56 chevy gasser build for 2017 meltdown or bust
Discussion in 'The Hokey Ass Message Board' started by fast30coupe, Jan 19, 2015.
  1. fast30coupe
    fast30coupe
    from Illinois
    Thanks I'm trying to make stuff happen.
  2. cs39ford
    cs39ford
    You are making it happen It just takes a little more time .The work is just outstanding !
    fast30coupe likes this.
  3. fast30coupe
    fast30coupe
    from Illinois
    Motors mounted. Was a nice warm day in Chicago.
  4. Now that is some nice , strong motor mounting.
    loudbang and fast30coupe like this.
  5. fast30coupe
    fast30coupe
    from Illinois
  6. Sweet surge tank. Did u make that? Are u gonna run a 4port?
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
  7. saltflats
    saltflats
    from Missouri
    Top notch!!!
  8. fast30coupe
    fast30coupe
    from Illinois
    Yea I made the surge tank. Street car stuff haha. If you look back in the thread it shows you how I did it. I'm going to run the 4 port. How is it on your t street driving with the 4port? I don't plan on ever going far just local cruises. The Hilborn looks killer on your car. Did you know the stacks were going to be that close to the top of the cowl or did you get lucky?
  9. they make four sizes of four ports. a short and tall and a large and small butter fly. the street cars have better tip in with the smaller diameter. impressive work.
  10. fast30coupe
    fast30coupe
    from Illinois
    I know mine is short not sure on the butterfly size
  11. My t has the large butterfly tall 4 port on it. It drives down the road great smoother than any of my other cars. I would drive that car anywhere. Cruises down the highway 1500 rpm in 5th gear no problems. I measured for my stacks but I think they are to tall I'm going to end up putting shorter stacks on it. To close to the cowl and front part of the hood.
  12. fast30coupe
    fast30coupe
    from Illinois
    Do you lean it out with the fuel shutoff? Looking forward to driving it to the local cruises. Where camaro, novas, and mustangs are the norm. Hopefully make an impression for some kids.
  13. When I first got my coupe going with the injection I would lean it out with the shutoff but after messing with spring pressures in the secondary bypass on the barrel valve I haven't had to do that for a few years. That car starts rite up and idles in freezing colt Temps also. When I had 6 Strombergs on it u couldn't get it to run below 50°. I'll have to look to see what I ended up for pressures in the main bypass and the secondary I want to say 14 in the main and 12 in the secondary. We just use the secondary for idle that way when u mess with the pill on the main it doesn't affect your idle at all so u don't have to touch the barrel valve. I also always set the main 2 pounds heavier that way it doesn't bypass there at idle either. We made a tool to set the pressures most injection people I have talked with did the same. It's just a air compressor regulator with a Guage on it that u can screw the bypass on the end of then just turn the pressure up until it pops the pop it in the bypass. It took a while to get it where it was happy but once it's happy I haven't touched it in a few years now. Obviously it doesn't always run at full potential but it runs good when it's cold and runs decent when it's 100°. It runs 9's when it's cooler out and runs 10.0's usually when it's hot out and that's exactly how I run it on the street.
    fast30coupe and loudbang like this.
  14. fast30coupe
    fast30coupe
    from Illinois
    That's all good info. Especially the main being heavier thank the secondary.
  15. fast30coupe
    fast30coupe
    from Illinois
    Have off from not until January 2nd so this will be the beginning of the great Christmas thrash.
    Christmas came early
    Had to drill for the fuel pump extension
    Butch M, mad mikey and loudbang like this.
  16. wrenchbender
    wrenchbender
    You have a better pic of the water cross over that bolts to where the water pump goes that thing intrigues me
  17. fast30coupe
    fast30coupe
    from Illinois
    I hand casted it myself.
    Jk
  18. fast30coupe
    fast30coupe
    from Illinois
    The lady and my mom we're baking Christmas cookies today.
    I made this nice aluminum baking pan but they didn't want it so I made a fan shroud out of it.
    Still needs to be drill welded and tabbed but a good start
  19. wrenchbender
    wrenchbender
    That is pretty nice What are you planning on doing for a water pump I see you have a remote t-stat housing
  20. fast30coupe
    fast30coupe
    from Illinois
  21. wrenchbender
    wrenchbender
    Nice deal I'm thinking of doing something like this but I don't like the whole fitting and hose deal out of the block but I like your crossover it looks nice in there that's more like what I wanted to do
  22. fast30coupe
    fast30coupe
    from Illinois
    I choose that because the Isky idle bracket bolts off the water pump this makes the fittings off the block a little complicated.
    They say the cross over is balanced and you can run water from one sides but i felt that one bank would've ran hotter. I'm going to run black lines and either black or nickel plated fittings.
  23. I hadn't checked up on this in a while, looking groovey boss!
  24. saltflats
    saltflats
    from Missouri
  25. loudbang
    He's on the naughty list.
    saltflats likes this.
  26. fast30coupe
    fast30coupe
    from Illinois
    Thanks gotta represent the 56s
  27. fast30coupe
    fast30coupe
    from Illinois
    For being in the garage so much. I had cookies. Luckily I have untill July to work them off.
  28. fast30coupe
    fast30coupe
    from Illinois
    Finished the fan shroud. First time welding aluminum. First time using rivet nuts. Those worked well. Overall I'm happy with it. Should do the job.
  29. saltflats
    saltflats
    from Missouri
    How did you like welding the aluminum?
    The stuff can be funny one time its all cool then the next time its completely different.
  30. fast30coupe
    fast30coupe
    from Illinois
    As you can see I didn't take any close up pictures. I doesn't look horrible, but not great. Tricky stuff like you said. You really need to think about how you are going to weld something.
