Hot Rods Blown 215, strombergs or single 4 barrel? My
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Apr 8, 2015.
  1. JimSibley
    JimSibley
    I'm putting together my motor for
    My next hotrod, the car will be a fenderless 33 3 window. My question is this, 2 strombergs or an afb? ImageUploadedByH.A.M.B.1428548537.973498.jpg ImageUploadedByH.A.M.B.1428548593.841008.jpg
    kidcampbell71 likes this.
  2. captain scarlet
    captain scarlet
    from Detroit
    Strombergs
    fauj likes this.
  3. how about the twin SU set-ups found on the Rovers
    Texas Webb likes this.
  4. I like the AFB, probably with a scoop.
  5. 270ci
    270ci
    It would breath easier with the AFB, but the Strombergs look much cooler. Since you're not lookin for max power anyway, go with the Strombergs....and if you're lucky they'll leak all over your blower to give it that nice gas stained hotrod patina. :D
    Texas Webb and kidcampbell71 like this.
  6. JimSibley
    JimSibley
    I'm thinking the strombergs will be plenty of carb. For it. I'm only running about 3 lbs of boost. I'm really leaning towers the strombergs, but I have had reall good luck with afb carbs on my blower motors.
    fauj likes this.
  7. I like the Rover/SU idea- would go nicely with the 215 :)
  8. earlymopar
    earlymopar
    To me the single 4 looks much better but thats just my opinion. What make / model blower is that?
    - EM
  9. JimSibley
    JimSibley
    The blower is an old magnacharger I picked up at a swap meet.
  10. The eddy looks wrong up there.
  11. modified1927
    modified1927
    I finally found an early magnacharger M220, its a pair of 110's like you have. Most of his intakes were torquers, Milled parallel to the crankshaft, but I like your wedge.. good luck with the 215.
  12. fullhouse296
    fullhouse296
    from Australia
    No more than 500 cfm eh .
  13. modified1927
    modified1927
    Don't know, Mine are 50mm's but have a friend with the versions that has a pair of 600 Holley Dbl pumpers and it is stock bore, with World product heads and good cam. 389 RWH in 31 model A, I'll try to find a picture tomorrow showing the engine (you can just see part of the left manifold and carb) IMG_4417.JPG
    loudbang and kidcampbell71 like this.
  14. carbking
    carbking
    The Oldsmobile Jetfires with the turbo 215 came with a single side-draft Rochester type R or RC, both were used, with lots of controls for the blower, alcohol injection, etc.
    If I didn't know better, I would have guessed all of the controls were made by Lucas ;) (they were not, but you get the picture).
    Olds finally offered a recall to those totally unhappy with the blower. The recall consisted of removing the blower and replacing it with a single Rochester 4-GC of approximately 375 CFM.
    Your project sounds like a lot of enjoyment.
    Jon.
