Technical Blowing 12v fuel pumps
Discussion in 'The Hokey Ass Message Board' started by OldoginMd, Sep 9, 2023.
  1. OldoginMd
    OldoginMd
    I am having major headaches over a 12 volt fuel pump install ….I have burnt up 4 so far !!
    I have done many of these with no problem
    Just TWO wires …positive and negative right ?
    I had an in-line 5 volt fuse on the last 2 ..
    blew them. Immediately
    All voltage is 12 volts
    Does anyone have any ideas ?
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Where is your pump elevation wise to the tank? Is your pick up line free and clear?
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    Burning up pumps or fuses? Fuses are rated in amps. A five amp fuse probably isn't able to handle the amperage draw from the fuel pump.
    427 sleeper likes this.
  4. OldoginMd
    OldoginMd
    DP , in one case the pump blew when the 5 amp fuse blew
    First 2 were on 15 amp was fuses
  5. G-son
    G-son
    from Sweden
    What pump, what pressure is it making, what current is it drawing, in what way does it die (autopsy time!)?
  6. OldoginMd
    OldoginMd
    All lines and wires are new ,elevation wise maybe 2 feet ?
  7. squirrel
    if the pump is two feet above the tank, that's the first thing you want to fix....put it below, or at least level with the bottom of the tank.
    And tell us what kind of pump it is, there are a lot of them, and they don't all work the same way.
    427 sleeper, Johnny Gee and nochop like this.
  8. ActionYobbo
    ActionYobbo
    Efi pump or carby pump?
    Are you using a non return fuel pressure regulator to tame an efi pump down to carby pressure?
  9. 19Eddy30
    19Eddy30
    from VA
    What Brand style,
    Bad Ground or Hot,
    Or touching , bad power switch,
    Arcing ,
    Try new test leads ,
    Gauge wire is not heavy enough,
    is there a relay in the wiring ? Or required?
    Bench test before installing that way you can see if pump or existing Wiring .
    CSPIDY likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    More on electrical. Does the vehicle use positive ground vs negative ground?
  11. 19Fordy
    19Fordy
    There isn't enough information to answer your question.
    It's time to post photos of your pump and it's present installation location
    and how it's wired.
    Pist-n-Broke likes this.
  12. Mike VV
    Mike VV
    from SoCal
    Critical questions -
    1 - Pump brand ?
    2 - Pump height from the bottom of the fuel tank ?
    3 - Is the wiring clean ? That is is there ANYTHING else wired into the PUMP wiring ?
    4 - Fuel line...INTO the pump and OUT, size (diameter) ?
    5 - Fuel filters before and after the pump) clear, NOT plugged ?
    6 - Pump power wire size ?
    7 - Wire length ?
    8 - Relay in the system ?
    9 - Switch type (quality) ?
    10 - CLEAN and TIGHT ground ?
    11 - What is the pump grounded to ?
    That's a start question wise !
    Mike
    winr and INVISIBLEKID like this.
