blower carb linkage pictures- updated with VIDEO
Discussion in 'The Hokey Ass Message Board' started by Paul, Jun 18, 2012.
  1. Paul
    Paul
    Editor
    pretty sure I saw a better picture of the linkage on this 4x2 setup here but dang if I can find it..
    anybody have a close-up of the business side of this setup?
  2. squirrel
    here's a different one...maybe it will help? (I hope Steve doesn't mind....)
  3. Paul
    Paul
    Editor
    yes, it looks a bit cleaner,
    same parts pretty much but different configuration
    I picked up one of those top plates a while ago and have been thinking of doing something with it
    thanks!
  4. Jmountainjr
    Jmountainjr
    If you use extra long throttle shatfs on the right side carbs, you might be OK without it, but if you use the "add on" shaft extender-or just want to be safe - you need a bar on the left side that supports all four throttle shafts. Some had bushings, some had bearings. I don't have a pic handy right now, but if you look around you'll find them.
  5. Jmountainjr
    Jmountainjr
    Here is a pic to get the basic idea.
  6. Slick Willy
    Slick Willy
  7. Paul
    Paul
    Editor
    thanks guys, this is very helpful
    here is an older picture of my setup, carbs and top plate just resting on blower
  8. Sumfuncomet
    Sumfuncomet
    BDS has a couple good pictures on their site and in their catalog. It is hard at first to hook all that up and index everything
    Roperly on the splined shafts. Make darn sure your throttle cable does not go "over center" or you will be in for a very exciting ride that ends witha load in your trousers!
  9. Paul
    Paul
    Editor
    Gathering up the bits and pieces...
  10. Paul
    Paul
    Editor
    slowly, slowly
  11. Flatman
    Flatman
    Wicked looking setup Paul, she should scream with that intake!
    Flatman
  12. Paul
    Paul
    Editor
    we will see how well it works shortly
    at roughly 160 cfm (these are 48s) each this setup has close to the same cfm rating as the single 4 that was on there
    of course it had secondaries and this will be all barrels operating in unison
    so it should act quite a bit different
    one thing I didn't notice was the air cleaners I have bump into each other
    if I use them they will need to be modified
    no big deal
  13. Paul
    Paul
    Editor
  14. BLAINE 816
    BLAINE 816
    Love those 471s ,great pics.
  15. Paul
    Paul
    Editor
    well she runs,
    need to mount the fuel log, it's just hanging by some bailing wire,
    I couldn't wait to hear it :rolleyes:
    just back from a short romp around the block
    runs pretty good but does need some tweeking to fine tune it
    idles a bit high and it could be a bit smoother too
    something happened to the audio in the vid, the reving at the start came from nowhere?
  16. Paul
    Paul
    Editor
  17. landseaandair
    landseaandair
    from phoenix
    Overload of awesomeness!!! Even had train horns and chickens.
  18. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Oh god when you rev it I got chills.....
    Love the way you routed the fuel lines. Slick Paul...very slick.
  19. Paul
    Paul
    Editor
    it definately has more power, no doubt gas mileage will be much worse
    and to get all four carburetors to return nicely meant double springing
    so the pedal is stiffer
    all in all very different than the single Edelbrock
    I think I like it
  20. Paul
    Paul
    Editor
    drove around for an hour os so doin the road tune
    she is very well behaved, easy start and nice response
    no overheating or bad behavior
    idle is still a tad higher than I like it,
    it's at about 850 rpm warm
    I will continue to fiddle with it while I drive it
  21. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    Congrats man, looks super sweet! Sounds like you are having better luck than I did. I had three 94's on my blower and always had a hell of a time starting it, acted like the bowls drained down and acted like it was flooding every time I tried to start it. I finally gave up and went with the dreaded 4 barrel.
