Ok, I've been a Body man for 17 years and havent had the pleasure of doing body work on a Model A. I am wanting to get my fenders as perfect as possible. but a flat block just aint going to get it the fenders are to round. what have yall used on the fenders to block them out. this thing has got to be perfect.
The flexible loaf of bread looking sanders from Eastwood will change your life, swear to God. These are the foam blocks with three stainless rods that you can remove to make the block reeeeally flexible. Spend 70 bucks for the 21 incher and you will throw rocks at all your other boards. http://www.eastwood.com/21-inch-adjustable-flexible-sander.html Good luck, -Abone.
I'll have to check those out. probably will wind up buying them but east wood wasn't around in the 30's-50s what did the old farts use. are are you still using.
