blinker and windsheild wiper diagrams for a 54 chevy
Discussion in 'The Hokey Ass Message Board' started by kyle paul, Dec 18, 2009.
  1. blinker and windsheild diagrams for a 54 chevy does anyone have them ?i need the wireing/vacume line diagram for the wipers and the wireng diagram for the blinkers for a 1954 chevy .. any help would be great . thanks
  2. Change it to electrick wipers u will like ti better there is a bolt on motor for it
    i will look for blinker wiring
  3. Ok they do not give colors
    there 6 terminals 3 on each side
    with the dirictional switch in the middle position
    1) from the center wire on one side u will find that all 3 wires have conuninty the center will go to the stop lite switch one side will go to rhe right light the other to the left
    2) the other side the wires will be open on all 3 the center goes to the Flasher
    the outter will be right front and left front acme as back
    3) that u will test by moving blinker switch
    4) the dash indacators goe to same wires as the front lights
    i have no way to copy and send it to you Jim
  4. Flatman
    Flatman
    Have a look around this site.
    http://www.tocmp.com/
    They have lots of schematics and manuals.
    Flatman
  5. ok found this
    yellow center ---to flasher----other side of flasher goes to ignition
    white center ----to stop light switch-----other side of switch to B+
    pink outter ------to left stop turn
    violet outter-----to right stop turn
    light blue outter--to left front turn and dash indacator
    dark blue outter--to right front turn and dash indacator
    this is out of factory GM book
  6. wiper hookup is manifold vacume to double action fuel pump then to wiper motor u will have to figure whitch line on fuel pumpone side sucks when u start motor that one goes to wiper
