History BILL SMITH’S.........ROADSTER
Discussion in 'The Hokey Ass Message Board' started by Austinrod, May 28, 2019.
  1. Austinrod
    Austinrod
    from Austin
    More photos
    Sent from my iPad
  2. Austinrod
    Austinrod
    from Austin
    Done up fore the 81 Oakland Roadster Show
    Sent from my iPad
  3. SS327
    SS327
    Those wire wheels almost look like Chrysler wires off of the 300 series 53-55 or so models.
    Denny
    Stogy and Austinrod like this.
  4. Austinrod
    Austinrod
    from Austin
    I’ve read the wire wheels he originally used were dodge
    Sent from my iPad
    Hamtown Al, Sancho and Stogy like this.
  5. Stogy
    Stogy
    :rolleyes:...pretty well documented. You are very fortunate...on top of having a solid base to step back with...this is a joy to watch...
    kiwijeff, Sancho, brad2v and 2 others like this.
  6. Austinrod
    Austinrod
    from Austin
    Thanks Stogy
    Sent from my iPad
    Stogy likes this.
  7. Austinrod
    Austinrod
    from Austin
    Back in 81 getting ready for red lacquer
    Sent from my iPad
    Hamtown Al and Sancho like this.
  8. Austinrod
    Austinrod
    from Austin
    Car meet today and looks like a Twinsie
    Sent from my iPad
  9. Stogy
    Stogy
    So @Austinrod was that a truspoke wire wheel or the original in that first Streetrod makeover before the Centerlines? I just looked I think they are newer stuff...
    The running boards to front fender were 1 piece all along and covered or separate and joined at the upgrade to the smoothed look?
  10. Austinrod
    Austinrod
    from Austin
    Don’t know if they welded the running boards in 81 or earlier
    The wire wheels in the 81 picture I think went on his other car the buick that’s now in a museum pictured below
    Sent from my iPad
    Sancho, Hamtown Al and Stogy like this.
  11. paul55
    paul55
    from michigan
    The '81 pics look like Tru-spokes.
    Stogy and kidcampbell71 like this.
  12. alchemy
    alchemy
    This '81 pic shows Buick Skylark wires. Not what is on the old pics of the roadster/sedan. Also not Tru-Spokes. Keep researching and soon you will recognize the differences at a glance.
    Sancho and Austinrod like this.
  13. paul55
    paul55
    from michigan
    Appliance wires
  14. alchemy
    alchemy
    I'm sorry, I misunderstood. Yes, the in-paint-process pic of the roadster does show Tru-Spokes. You were right. The black Buick wears Buick Skylark wires. The old-old pics of the roadster are neither Tru-Spokes or Buick.
    Sancho likes this.
  15. Austinrod
    Austinrod
    from Austin
    Checking bolt pattern and spacing for wheels/tires
    I’m thinking 15x8rear/15x6front OE wheels from wheel vintiques
    And 820 tires rear / 670 front
    Sent from my iPad
    Sancho likes this.
  16. Austinrod
    Austinrod
    from Austin
    Sent from my iPad
    Sancho likes this.
  17. Stogy
    Stogy
    Good candidate for Photoshop...where are those tires and rims...its a form of subtle torture. I still find it interesting how certain old time Custom/Hotrodders never upgrade their rides with the new...others cut slice and the original fades away...
    I might have mentioned this...I just find it hard to believe he would have saw those rims and tires a compliment...Damn I'm glad you got this Survivor...;)
    slv63 and Austinrod like this.
  18. Austinrod
    Austinrod
    from Austin
    Here’s the engine bay
    Last picture is the scratched out 1982 California license plate tag
    Sent from my iPad
    brad2v and Sancho like this.
  19. missysdad1
    missysdad1
    My guess is that the car got a massive front and rear suspension make-over, perhaps at the same time the engine was up-dated, and in the process the front and rear track was reduced from what it was when the historical (Generation One) photos were taken. There is no way the deep-dish Centerlines would fit on the original axles - the ones which wore the original Dodge/Plymouth wires - without sticking 'way out beyond the fender lips.
    This is a "restoration" problem which cannot be fixed with wider wheels - at least on the front. The car will look the same when the wheels are pointing straight ahead, but the slightest turn of the front wheels will give the narrower axle away visually.
    If the original owner/builder is still available I'd grill him on what the original suspension was - stock '34 Ford? - and go about changing the front suspension back to the previous axle width and proceed with the project using the original size and offset wheels and large diameter tires.
    The rear, of course, can be fudged with spacers but with wider wheels the tall bias ply tires aren't going to look right - they'll look too fat for the tread width. I really don't see a quick and easy "fix" for this problem in the rear either.
  20. Stogy
    Stogy
    This Custom has several articles and relevant paper and all those details would be available I suspect and @Austinrod will if needed I'm sure look at all the variables.
    50 Olds Rearend & Ford Front Axle
    Austinrod, missysdad1 and Hamtown Al like this.
  21. missysdad1
    missysdad1
    Perhaps I misread his last post. It sounded like he was just going to order some new, wider steel wheels and call it a day. His car so he can and should do whatever he wants. I was just trying to be helpful.
    Stogy likes this.
  22. Stogy
    Stogy
    I understand...I suppose its going to be a journey in transitions selectively made and the owner who is the original is a phone call away. You raise a good point as in what has been done under there....and Austinrod is ordering Vintage inspired in the rim department with Piecrust www Bias I think.
  23. Stogy
    Stogy
    @Austinrod what with the Phsycodelic Plate Job was that a custom touch?:confused:...sorry if you explained it I might have missed it...
  24. Austinrod
    Austinrod
    from Austin
    Has a 4 inch dropped axle split bones bolted too the frame
    Disc brakes added to the front in 81 and probably 81 shocks front and air shocks on the rear also ten bolt I saw so that was changed also everything else looks original but
    Need too look further
    Sent from my iPad
  25. Austinrod
    Austinrod
    from Austin
    The wheels on there now are 15x9 plus one inch for tire width
    The front are 15x7 plus one inch tire width
    Sent from my iPad
    Sancho likes this.
  26. Austinrod
    Austinrod
    from Austin
    You can see how wide the wheels are in rear and front
    Rear
    Front
    Sent from my iPad
  27. Austinrod
    Austinrod
    from Austin
    Bill at the drags in Fremont 81/82
    Sent from my iPad
  28. Stogy
    Stogy
    :rolleyes:...It's a Big Back Attack...;)
    a stunner in my books...Oh Yeah...
    stanlow69, Peanut 1959, slv63 and 8 others like this.
  29. Austinrod
    Austinrod
    from Austin
    Peanut 1959, 41 coupe and Stogy like this.
  30. Stogy
    Stogy
    Thanks...I can't find the top or the spare tire...Yet...:D
    This Custom/Hotrod has went thru a ton of subtle changes in the Late 50's, 60's
    I just noticed a chrome side pipe while running duels out the back...Are you running those?...I mean they are kinda Hotrod in a good way...This was a Sleeper in a way...
    Sancho, cactus1 and loudbang like this.
