Big Block Chevrolet 396, Supercharged Built for v-drive boat-easily convertible to street use. Basically a stock 1967 396 Chevy BB with: Fresh rings and pistons Checked crank for cracks and finish Oval port heads New RV type cam and lifters Dan Olson oil pan BDS 6-71 blower Mooneyham manifold Carter Comp Series carbs- flowed for this application Aluminum “surfer” scoop Vertex magneto River rat water pump Edelbrock mechanical fuel pump New hi torque starter Vintage Cal-Custom valve covers BDS/good vibes blower drive & belt NO EXHAUST logs included Engine has less than 10 minutes of run time from being pulled from boat hull that was sold. Ready to run. Engine is built for low performance and cruising, to look sharp and make some noise with blower. It is not built to race or beat on. All by design. Comes with everything pictured including stand $7500.00 Please email [email protected] with a contact number and I will promptly return with a call. Delivery possible for a fee. thank you, Don
