BF Goodrich radials -- radial TA or Long Trail?
Discussion in 'The Hokey Ass Message Board' started by Fenders, May 6, 2013.
  1. Fenders
    Fenders
    Well I went with the 235/70R15 Radial T/A tires.... 1/2" wider and higher than the old 225/70R15 that were on there.... see photos.... new on left, old on right...
    With the axle I have (S-10 2WD) and the backspace on my wheels (about 3-1/2" as I recall) that's the max width I could use before they hit the inner fender brace.
    Nicer ride, don't know if it's the new rubber or the wider tread, but I'm happy.
  2. MATACONCEPTS
    MATACONCEPTS
    Yeah! That's what I was gonna say.
  3. MATACONCEPTS
    MATACONCEPTS
    Show us some good pictures of your ride, ese.
  4. 54rat210
    54rat210
    Who cares?? Its your car. Do what you want. Your the one who hs to drive and look at it! ;)
  5. I get it about Radials all the time
    that is all I run
    they work better in the rain here in FL
  6. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    I'm considering running Radial T/A's as well. I'm used to radials, I've run a set of these before and I can get them and a set of new steelies for less than I can put tubes and bias plys on the vintage wheels I have. I'm still on the fence though.
    Was looking at
    BF Goodrich T/A RWL - 155/80R15
    BF Goodrich T/A RWL - 225/70R15
  7. Fenders
    Fenders
    Height sounds good -- fronts would be 24.7, rears 27.4 (calculated).
    By the way one thing when I went from the old 225/70 to the BFG 235/70, what a difference in weight !
    Old ones 48 pounds each, new ones 58 pounds (with same wheels).
    More unsprung weight but still a nicer ride.....
  8. patmanta
    patmanta
    from Woburn, MA
    Yeah, I'm actually a little concerned about my build being too light. The only major component I can't lift by myself is the engine. Weight out back is a good thing!
