Kinda’ a newby question, but I don’t want to end up with any air pockets in the block. I am putting a new three row aluminum radiator in my ’49 and want to make sure I get all of the air out of the block....so what’s the best way to burp the system IF you don’t have one of those fancyass funnel things...any help greatly appreciated
If it's got a heater, I'll take the highest heater hose loose to let air out. I'll remove the thermostat and fill the engine to the top and let it sit for a minute....refill and put the thermostat in and start filling the radiator till water runs out the heater hose...if it's higher than the radiator fill I'll fill the radiator 'till the tank's full and put a few inches in the overfill tank. start the engine and let it run while waiting for coolant to run out of the upper heater hose. When it does, I hook it back up and tighten the clamp. I keep a container of coolant close by and run the engine while keeping the top tank almost full. When the thermostat opens, the level will drop and you'll see coolant running inside the radiator. refill the top tank 'till it's about and inch below the fill...done.
Run it into the radiator very very very slow. At the 3 gallon limit start the engine and get the pumps turning. Continue slowly, finishing up the fill.
Drill the 1/8 inch hole in the tstat flange. Use a radiator pressure checking tool and pump to 8-10 lbs. let it set for several minutes. Add water and do it again.
There is a filling system used for new cars that works very well. It pulls the system under a vacuum using compressed air and then uses the vacuum to pull the coolant into the system.
