Best dropped front axle for 32-34 Ford Truck?
Discussion in 'The Hokey Ass Message Board' started by travj31, Oct 3, 2011.
  1. Just what the title says... which one is the best out there?
  2. el Scotto
    el Scotto
    from Tracy, CA
    I'd have to say a dropped stock 1932-1936 axle. :)
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    I'll second that dropped original axle.
  4. I'm using a Chassis Engineering 4" drop Heavy 1932 axle.
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
    As long as it's a forged axle, it's good.
  6. hotrod-40
    hotrod-40
    Drop an original. I dropped one for my brothers truck and it looks sweet.
  7. Any stock Ford axle will look great and can be dropped. Several vendors on HAMB that are doing the dropping service.
    Don't use a cast axle if you go aftermarket. Make sure it is a forged axle.
  8. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    At the time I didn't have a dropped original so I put a SO-Cal forged I beam axle and hairpins under my deuce pu because I could use stock 37/41 spindles and they turn lock to lock without any bending of the arms. Incidently I've sold many hundreds of cast Super Bell axles and have had no problems.
  9. hotrod-40
    hotrod-40
    I've seen cast axles break...
