It’s dangerous to jump on a cruiser bike when you don’t have the best cruiser modular helmet. If you want to enjoy every second of the ride, feel safe and comfortable then you can’t do without a modular motorcycle helmet. Best Cruiser Modular Helmet Some riders feel claustrophobic and in a prison-like setting when they wear a standard full-face helmet. If you fall into that category, then the solution lies in securing the best cruiser modular helmet. Read on for the viable tried and tested options: Bell SRT Cruiser Modular Full-Face Helmet 2X-Large (premium choice, fiberglass shell) If you need the cruiser modular helmet that’s very light, then the Bell SRT is hard to beat. Bell has used premium fiberglass as the shell material and thus its 3.3 lbs weight. Your neck muscles will appreciate you for the lightweight. Unlike other flip-up helmets, Bell SRT employs the Panovision class 1 optics on the clear visor. That makes the shield thick and extra clear. So smaller objects hitting the visor won’t threaten its durability. When it threatens to smell, removing the liner and cleaning it restores its fresh smell. Bell has also placed deep speaker pockets in the EPS padding. Considering its degree of comfort, quality design, and DOT FMVSS certifications, the Bell SRT counts as the premium choice of the best modular motorcycle helmet. Pros: Lightweight and thus less straining on the neck Feels very comfortable to wear Provides a snug fit Attractive appearance Cons: Replacing the darkened visor is somehow tedious ILM Motorcycle Cruiser Modular Helmet for Adult Considering its moderate price and batch of quality it packs, the ILM 906 is a helmet worth the investment. ILM taps on injection molded ABS and high-density EPS liner in the hood. And the result is a 3.97 lbs cruiser lid that has optimum impact-resistant protection. Further, the manufacturer gives it a streamlined aerodynamic sharp to minimize the drag and wind noise. Its double visors have tough impact-resistant ability. For convenience during your cruise rides, a side-located switch enables you to retract the darkened visor with ease. When you fasten the quick-release buckle, the helmet holds to your head securely. Releasing the buckle makes it easy to wear on or off the hood. As for air flow, the thick high density having numerous vents does the trick. The strategic ventilation at the front top and back guarantees ample flow of air. Pros: Easy-to-follow instructions Provides good fit according to sizing chart Compatible with sunglasses DOT certified quality Cons: A secure locking mechanism could have made it much better Read morre : Top Modular Motorcycle Helmet Brands: Reviews and Buying Guide AHR Motorcycle Helmet Dual Visor Modular Flip-up Full-Face Helmet for Adult Motorbike Street Bike Moped Racing The AHR makes up a viable backup or cruiser flip-up helmet for the budget-conscious group. On the outer cover, it features an ABS shell and weighs 3.75 lbs. Underneath the shell, there is the thick EPS liner cushion. So, for occasional rides, it counts as the best cruiser modular helmet. Though affordable, its safety standards meet DOT FMVSS 218 threshold. On the shell, the AHR helmet has ample intake and exhaust vents at strategic parts to keep the hood ventilation. The thick EPS liner has a design that’s breathable and features nice speaker slots. Cleaning the helmet and keeping it fresh is simple since the lid has a fully removable interior. For convenience AHR awards the helmet a clear and switch-controlled smoked visor. Putting on and off the helmet should be simple by making use of the quick-release buckle. Pros: Lightweight Optimized ventilation Streamlined shape that cuts down drag and noise Cons: The outer visor sometimes snaps down amidst your ride HJC i90 Solid Cruiser Modular Motorcycle Helmet HJC has always been promising when it comes to helmet quality and the HJC i90 is no different. The company uses an advanced polycarbonate composite to make a sturdy shell fitting the danger of cruiser rides. Its CAD design, 7 intake, and 2 exhaust vents deliver optimum airflow. Added to the moisture-wicking interior that’s removable, you’ll appreciate the supercool feeling interior. As with other standardized cruiser helmets, HJC places dual visors in this i90 model. Other winning features that make it the best cruiser modular helmet are its secure shield ratchet and reliable double D ring closure. For convenience, the HJC flip-up hood has a simple visor replacement mechanism and a one-touch adjustable sun visor. Whereas the smoked visor adjusts to three positions, the clear outer visor supports a wider field view. Pros: Reliable brand and quality Easy to use ECE and DOT-certified Cons: Somehow heavy How to Choose the Best Cruiser Modular Helmet There is an uncountable number of helmets offered for sale. For that reason, selecting the best cruiser modular helmet is tasking for even experienced riders. Read morre : Everything related to the modular motorcycle helmet But you can simplify the task by implementing a few ideas. First, search for a helmet that fits and feels secure on your head without threatening to come off at a slight shake of the head. Also, make sure the shell material is of reliable quality and the underneath padding is of sufficient thickness. When you wear the hood, it should feel comfortable and support adequate flow of air. Therefore, the number and location of the vents count. Prioritize only the DOT, ECE, and SNELL-certified cruiser helmets from reputable brands. And keep off any hood that has no certification from a reputable body. The helmet will get dirty over time and call for cleaning. A helpful tip on how to clean a motorcycle helmet is to choose a model that has a removable liner or padding. Don’t overlook the locking system; a quick-release system or double D ring feels reliable and easy to use. Further, a strategically located visor button or slide for deploying or retracting a shield is crucial. Conclusion The trick to enjoying a ride on your cruiser bike lies in feeling comfortable and safe. Therefore, take your time to choose the best cruiser modular helmet on the market. When shopping around, take a keen interest in size, fit, adequate padding, certification, and the nature of the material used. Our recommendation for the top choices goes to HJC i90 and Bell SRT but only you understand the cruiser helmet you need and your budget. Happy shopping.
Putting your location in always helps, in case someone is close. A picture of the booster would also help, maybe someone could identify it. There’s a similar post going on here with the same types of problem. Seems odd it’s the same title. https://www.jalopyjournal.com/forum/threads/1962-ford-mercury-brake-booster.1312310/
