Technical Best Chassis Paint?
Discussion in 'Traditional Hot Rods' started by Jellowe, Feb 19, 2021.
  1. Jellowe
    Jellowe
    I have ordered a complete new chassis and suspension for a model A coupe. All the parts will arrive in bare metal finish. I have s painted a few cars and many motorcycles so I have some experience painting. I want to apply a satin black finish while avoiding the time and expense of powder coating. Eastwood offers a frame paint in quarts and aresol and they say it does not require primer. I would love to know what folks are using for frame paint on a new build.
  2. I used Pors-15 on my grandsons OT El Camino.
  3. whiteknuckle
    whiteknuckle
    from Dryden, NY
    PPG Delfleet with the appropriate flattening agent. Flows like glass and very durable.
    Speedy Canuck and BigChief like this.
  4. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
  5. mcsfabrication
    mcsfabrication
    I used the Eastwood black semi gloss ceramic chassis without primer. Four years and around 35,000 miles, looks just fine.
  6. ghalperin
    ghalperin
    I did my frame with Magnet Chassis Saver epoxy. I used a HarborFreight $10 gun. I cleaned the gun while I was doing the frame and suspension and then tossed it out. It turned out great. I didn’t wear a respirator at first and got dizzy AF.
  7. Rustoleum enamel is what I used on the suspension part and frame under the Ranch Wagon. HRP
  8. SPI black epoxy primer
    Frankie47, Paulz, Sporty45 and 2 others like this.
  9. TCATTC
    TCATTC
  10. X 2 what Gary 2deuces64 said
  11. bill gruendeman
    bill gruendeman
    I like spi black epoxy, great stuff but for me it’s too shiny for chassis paint.
  12. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    My deuce pu has the frame powder coated satin black and the suspension powder coated gloss black.
  13. juan motime
    juan motime
    Rustoleum enamel - what HRP said. Make sure your metal is clean and use the same color primer. Works well for me. Easy to touch up.
    Frankie47 likes this.
  14. wvenfield
    wvenfield
    For a frame I go over to the tractor supply store and get tractor paint. It is cheaper and holds up on tractors so................
    Robert Maryland and WB69 like this.
  15. HSF
    HSF
    from Lodi CA
    Whatever you paint it with, take the little bit of extra time and expense to shoot a direct to metal sealer first. I use House of Kolor KD series. KD3001 is black. Stuff bites like crazy and no need for sanding in between sealer and topcoat. Shoot it, let it flash and paint it. Good luck.
    BigChief likes this.
  16. indyjps
    indyjps
    Black urethane single stage. I order from tcpglobal with a flattener added, call and request - they add by weight.
    Eastwood has a urethane chassis paint. Kirker has several gloss levels in black urethane.
  17. Jellowe
    Jellowe
    Do you shoot the color coat over bare metal, no primer?
  18. WB69
    WB69
    from Kansas
    I have done the same thing with great results. Holds up well. Also at Orschelin's.
  19. indyjps
    indyjps
    Over epoxy, generally. Ill shoot urethane direct to metal if its freshly blasted and has plenty of tooth. Its my stuff, I dont do any paint work for others. I work so slowly, everything I work on gets a coat of epoxy once its clean.
    Its a good point. An epoxy chassis black with UV would be a good option, if the gloss level is right. Now ya got me thinking.
    Is there a medium gloss epoxy black with UV protection?
  20. Sporty45
    Sporty45
    Yup, good stuff :cool:
  21. Pats55
    Pats55
    from NJ
  22. John Deere "Blitz Black". They use it on tractors. A lot of tractors are left outside and the paint holds up very well.
    Roadsir likes this.
  23. Pats55
    Pats55
    from NJ
    If you paint the pieces separately ,then bolt it together you will break the paint film around the heads of the bolts which will cause the rust to travel. I would suggest wiping the chassis down with rust remover / metal prep ,assembling the chassis and then coating it.
    There's only one primer that I know of ,that if it's scratched , the rust won't travel beyond the scratch
  24. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    I haven't laid it on yet but I'm going to try some Rust Bullet on my frame.
  25. Jellowe
    Jellowe
    Thanks for the experiment. How did your final paint job come out?
  26. Brand new metal? Wow
    Then just clean and paint like normal.
    Wax and grease remover, sand/clean/epoxy.
    Use a decent automotive or industrial urethane.semigloss or flat.
    there are some industrial DTM paints.
    I would trust those much more than rattle can.
    PPG has a low cost semi gloss black in their Essentials line. Looks good, easy to shoot.
  27. I really dig duplicolor's acrylic enamel in semi-gloss. Sprays nice, is tough, and looks killer!
  28. neds29
    neds29
    Hey Glenn- How about a pic of your roadster? Ned
    1929 Ford Model A Roadster
    Prewar style Hotrod. Stock springs and ride height. 6 volt positive ground. Stock mechanical brakes. 1933 Model A factory replacement “Diamond” block. Model A trans & rear axle. Winfield SR B carb and matching Winfield intake manifold, Winfield ‘30s cast iron 6.1 “Yellow” head, Winfield SU1R cam, ‘32 Ford Model B distributor, NOS (‘80’s or earlier) 4 into 1 tube header. ‘32 Ford throttle linkage and spoon pedal. Rex-A-Co water temp gauge mounted in an early ‘30s Motometer column mount. Windshield chopped 5 1/2” and laid back. Steering column dropped with 2 stock Model A lower column clamps inserted. Roof chopped 6” in the back. Seat lowered 6" and moved back 6”, 3/4” plywood bases with memory foam. Repurposed all vinyl and canvas from ‘70's stock restoration. Rumble seat. Air Force surplus seatbelts. ‘35 Ford wire wheels. 6.00 & 7.50 Firestone’s. Guide 903J Headlights with original paint. Chopped and bent Model A headlight bar. Model A brake cross shaft repurposed into a front spreader bar and license plate holder. Model A rear bumper bracket and cross bracket repurposed into a rear nerf bar. Surfboard racks, 1”x1/2” steel tube wrapped in 1/4” cotton cord.
  29. blue 49
    blue 49
    from Iowa
    I've had Blitz Black on my '36 frame for about 12 yrs and it still looks good. I blasted my frame, etch primed it and sprayed the paint with hardener. The can says it can be used direct to metal. A lot of the black on the tractors is an
    E-coat process, or at least it was 35 yrs. ago.
    Gary
  30. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    If you don't paint it shiny,it will be messy looking after a short time,shiny cleans up! ,flats an no shine don't.
    Great for the $,Gloss Black Rust-Oleum has worked well for me for over 60 years an can be fixed with a spraycan if needed.
    TrailerTrashToo likes this.
