"Beside the Barn" willys find
Discussion in 'The Hokey Ass Message Board' started by ME.GASSER, Jun 2, 2010.
  1. HotRod60F100
    HotRod60F100
    Amaaaazing skills and glad its saved from rotting away or being turned into a Toyota!
  2. ME.GASSER
    ME.GASSER
    I want to thank you guys for the compliments. I spent some time this week installing the two patch panels that i made. It takes alot of time and patients to make a weld this long and not distort the metal. I was quite happy with how they came out.
  3. ME.GASSER
    ME.GASSER
    [​IMG][​IMG]
    I was working on the doors. At some point somebody welded the hinges to the body. I cut them free and spent about 10 hours realigning them. The drivers side door hit the striker. It had a shim behind it so i took it apart to remove the shim. What i found was that at some point the striker had broken free from the body and the shim and a couple of washers was what they used to do the repair. One picture is of the hole cleaned up. The other picture is of the cage i made to hold the bolt plate and of the patch for the hole.
  4. ME.GASSER
    ME.GASSER
    [​IMG][​IMG]
    The left picture shows the cage installed. The right picture shows the repair completed.
  5. langy
    langy
    Awesome thread, your a lucky guy.
  6. ME.GASSER
    ME.GASSER
    With the striker installed.
  7. ME.GASSER
    ME.GASSER
    This is how i wanted the door to fit. Alot of work but well worth it.
  8. ME.GASSER
    ME.GASSER
    Langy,
    I only wish i had half your talent. Your project is just awesome.
  9. ME.GASSER
    ME.GASSER
    [​IMG][​IMG][​IMG]
    Lower left quarter panel damage. After i removed the patch panel i dicovered damage to the door post. [​IMG]
    I fabed up a new repair panel and it's ready to weld.
  10. captainjunk#2
    captainjunk#2
    great job on the car, that drivers door seam lines up awesome ,
  11. ME.GASSER
    ME.GASSER
  12. The37Kid
    The37Kid
    What a great project, just went through the thread and feel I'm up to speed now. I always enjoy seeing restorations were the owner makes missing parts, and saves a rough project. Look forward to more updates. Bob [​IMG]
  13. 37willysgasser
    37willysgasser
    glad you kept the car, great work saving another old gasser!
  14. gassercrazy41
    gassercrazy41
    Larry, its looking great! Keep the pics coming!
    kyle
  15. Boss Hydro
    Boss Hydro
    from Phila
    Very coo project done by some very cool people! I can't wait to see her back on the track again!
    Rocky
  16. JT Apperson
    JT Apperson
    from va
    Hope to see ya at the York, Pa show in july.
    JT
  17. ME.GASSER
    ME.GASSER
    Thanks Rocky. Can't wait to see you this year.
  18. ME.GASSER
    ME.GASSER
    Jt,
    Our year is kind of up in the air because of a family medical issue but we hope to be there. Make sure to say hi.
    Gasser Girl
  19. ME.GASSER
    ME.GASSER
    [​IMG][​IMG]
    Made a little more progress on the coupe. While i was waiting for parts to arrive i decided to tackle a few small projects. First was to add a pocket in the top of the cowl for the hood hinge. The cowl is a 37 and they are completely different. The picture showing the top of the cowl shows the two holes on the sides where the hinge would go. My original plan was to plug these holes and create the hinge pocket. My friend Randy (thanks Randy) talked me into changing the cowl top to a 40. To do this i had to remove the firewall. This requires drilling out about 40 spot welds. The cowl top requires drilling out another 40 spot welds. So you can see we turned a small project into a big one but it will be worth it. While i had the firewall out i plugged all the holes.
  20. ME.GASSER
    ME.GASSER
    [​IMG][​IMG]
    The first picture shows the 40 cowl top in place. The second is the firewall installed.
  21. ME.GASSER
    ME.GASSER
    [​IMG][​IMG]
    While i was working up front i decided to repair some issues with the windshield wiper holes. At some point they brazed patches over the original holes and hammered them flat. Then later they drilled new holes next to the old one's. I knew that i had work to do here so i saved the front of the roof from the old sedan and cut out the pieces that i needed and welded them in place.
  22. ME.GASSER
    ME.GASSER
    My quarter panels and door bottoms showed up late lastweek so i decided to tackle them. First is the right quarter. I spent part of yesterday and today fitting and adjusting so that it suited me. It is now all welded in place. The vise grips are holding in the filler panel that goes between the floor and the quarter. That is also welded in at this point. I lined up the inner fender and completly welded that in place. All i have left to do on this quarter is intall the 5 cage nuts. I will tackle the other side tomorrow. What a way to spend a week off:D:D
  23. ME.GASSER
    ME.GASSER
    I finally got the left side quarter on. I had to do some adjusting on the inner fender to get it to line up all the way around. I'm happy with the finished product. I did get delayed working on another little project. I will post a picture of it here.
  24. ME.GASSER
    ME.GASSER
    This little hot rod is for our god son Gavin. It had a few dents, a few tears and the front was pushed in. I bead blasted it, welded all the cracks and repaired the front. My nephew (the god son's father) will be painting this. He paints all of my cars for me. He's an awesome painter, graphics artist and pin stripper.
  25. ME.GASSER
    ME.GASSER
    We know that there is a wanted section on the site but since it has to do with this build we thought we would put it here. I need a few parts. I am looking for one rust free door garnish moulding. I also need a pair of trunk support arms and if anybody has a rust free package tray i could use that as well. These pieces are all that i need to make this an all steel willys. If you have anything PM me a price and i will get back to you. Thanks.
  26. slicksona66
    slicksona66
    from Lincoln Ne
  27. paco
    paco
    from Atlanta
    I can only say ... WOW!!
    I will continue to watch with my mouth wide open.
    Paco
  28. richie rebel
    richie rebel
    awesome thread,keep up the good work
  29. ME.GASSER
    ME.GASSER
  30. HotRod60F100
    HotRod60F100
    The 60's Willys gassers were so cool yeah,but i hated how some were sawed up for racing.Glad your putting the body back with stock parts again like the firewall etc.
