I have two bendix Zenith single barrel carburetors. I have not been able to find any information on them, the only thing I know about it, is I got both of them off of two old forklifts. They resemble Strombergs, or holley 94 kind of the same general look, are these some carbs I can put on double/tri carb set up? 1shot
You are going to put a double/tri carb set up on a fork lift??? Seriously, carburetors designed for industrial use, as a general rule, require major modifications to put them in an automotive environment. Generally, there are carburetors to start with which are much easier/cheaper to modify. Without knowing the identification numbers of the carburetors, the general answer above is about all I could suggest. Jon.
I'm running two on the 6 cyl in my T. Cal Bill Fisher recomended them years ago in his book. Jon is right on needing an ID as they were very universal on orpfan trucks & equip . They are very tuneable with removable venturies ect. I belive mine were used on '54 GMC pickups.Dare to be different.
Ok thanks for the info i'll get a number off of it. I know they come off of 6 cylinder engines. And no I am looking to put the them on a car lol. 1shot
the whole key to identifying a Zenith is the number on the little round tag on top of the fuel bowl. The rebuild kits are still avail. on the Internet, the ones I have dealt with were on old International trucks. Between a carter1 barrel and a zenith I would take the zenith every time---very tunable
