bending window channel at the B pilar
Discussion in 'The Hokey Ass Message Board' started by shoprat, Nov 25, 2007.
  1. shoprat
    shoprat
    from Orange, CA
    I'm replacing glass, seals and channel in my 57 Ranchero (everything). Does anyone have a good way of bending the 90 degree where it goes from the top of the glass down the B pilar
    so it doesn't look like a 2 yr old did it?
    Thanks, Ron:eek:
  2. brownsmetal
    brownsmetal
    Simple, before you start bending on your new channels cut off the ends of the little chrome bead on both sides with a cutoff wheel. They alwasy come new with the chrom ebead cut off with sidecuts or something. you want to cut off the crimped end. This will let the chrome bead move on the channel when you bend it. It keeps it from kinking in the corner. I always have the glass out when I do these so I bend my new channels aroung the glass using it as a form.This will give you perfect corners.
  3. Brownsmetal, thanks for that answer. I messed up enough of those channels, never thought of the stupid crimps!!-MIKE:cool:
  4. shoprat
    shoprat
    from Orange, CA
    Brownsmetal, thanks for the reply. Sounds good to me
