Technical bending a chrome pipe
Discussion in 'The Hokey Ass Message Board' started by blowby, Dec 11, 2018.
  1. blowby
    blowby
    from Nicasio Ca
    I need to bend a 1-3/4" chrome exhaust pipe, not much, maybe 3-5 degrees over a foot long section. Tried it cold clamped in a vice between wood blocks, couldn't budge it. Torch time I guess, and goodbye chrome?
  2. squirrel
    take it to an exhaust shop, have them put it in their bender. And see how the chrome plating explodes at the bend.
    da34guy likes this.
  3. I have “tweaked” chrome exhaust pipes in a hydraulic exhaust bender before, grease the dies beforehand and try.
    Go slow and see, I have done a few successfully and some that have cracked the chrome and some where as squirrel stated the chrome shatters and comes off completely 50/50 shot.
  4. FrozenMerc
    FrozenMerc
    Hang the chrome pipe on the wall, buy a stainless section (about $12/ft through Summit or Jegs), bend, polish, replace.....
  5. pkhammer
    pkhammer
    Ditto FrozenMerc.
    lothiandon1940 likes this.
  6. jimmy six
    jimmy six
    Those little blades of chrome your going to cleanup will cut the hell out of you. Remember to wear gloves and use a brush into the dust pan.
    loudbang and williebill like this.
  7. fullhouse296
    fullhouse296
    from Australia
    Cant be done . Go SS .
    jimmy bruns likes this.
  8. dreracecar
    dreracecar
    from so-cal
    Depends on the plating, if its the cheap "flash Nickel" good chance of it poping. Triple on the other hand is more forgiving. How come chrome bumpers back in the day bend in an crash and the chrome didnt come off??
    VANDENPLAS and loudbang like this.
  9. squirrel
    bending a tube is not the same as bending a curved sheet...
  10. dreracecar
    dreracecar
    from so-cal
    Bent a lot of chrome "nerf bars" on my sprinter without the chrome peeling
  11. squirrel
    Did you bend them in a tubing bender? or with another car?
    milwscruffy likes this.
  12. indyjps
    indyjps
    Whats the chrome pipe attach to, Can you bend that instead.
  13. blowby
    blowby
    from Nicasio Ca
    Stuck it in a press yesterday between wood blocks I cut u shapes in. Heard a couple snap crackle pops but no progress. Muffler shop next, it's already messed up I guess.
  14. pitman
    pitman
    If it is triple chrome, Cu is the base-filler layer, Ni is the 'hard', followed by Chrome. Which as topcoat gives it the desired 'color'.
    Electrolytic deposition, in this case offers a thin, brittle coating. I'm w/Jim on this one
  15. Chevy Gasser
    Chevy Gasser
    Yep! It's SS time.
  16. B Ramsey
    B Ramsey
    i would fill it with sand, cap ends with duct tape and give it a try. maybe stick it in a trailer hitch receiver and jump on it or something like that.
  17. pitman
    pitman
    ^^^ Might plug each end w/an expanding freeze plug.
  18. cshades
    cshades
    from wi
    Have you tried laying down an oxygen bottle on the floor, mark off the section you want to bend with masking tape and with the help of a friend on each end of the pipe push down and roll it back and forth over the bottle? I had a freind show me this trick and I have used it for a lot of things to get a gradual/small bend in any kind of tubing
