Fellow HAMB'ers: I've got a cheepie sandblast cabinet that resembles this unit: http://www.mytscstore.com/detail.asp?pcID=1&paID=597&sonID=597&productID=2526 Anybody got a supplier for the replacement window for this thing? Or a good idea on how to keep it from going opaque? OR a good idea on replacing it with something bulletproof? Yours truly 85% Jimmy
Good news and bad news... #1. the glass will ALWAYS get fuckered up. #2 go to home depot and get 3 panes cut (of their "el cheapo" window glass) should cost about 15 bucks. install all 3 and remove the innermost peice when you find yourself doin' the "sandblaster lean" (so you can look through the lower right hand portion of the glass which for some reason never gets as bad as the rest of it... oh yeah. the clear plastic liners suck for the blaster, but make great bird cage liners.
Harbor Freight sells stick-on clear plastic sheets. I put one on inside, and outside, replace when needed.
contact " Tip " company they sell anything you need for your blast cabinet. You can get thin lexan sheeting or rolls of this material to use under your glass it will work just fine been using it for 4 years with no problems DO NOT use plain window glass, use safety glass regular house window glass can shatter in a blast cabinet and your face is usualy right there.
I use the clear film you put on the inside of the glass. If you wipe it off after every use it seems to help make it last a little longer. I want a light inside mine, anyone see those anywhere?
my TIP cabinet has a light inside. when i bought the unit it was an option , so i'm sure they would sell it separetely
I get regular window glass from a hardware store, cost about 4 bucks. Just keeping changing it when it gets buggered. I get three or so at a time so I have some on hand. I use regular window glass, cut to size. Never had a problem with it unless I hit the glass with what I'm blasting
Most hardware stores do storm door and window screen replacement. they will cut you a piece of lexan for a couple of bucks. I put a piece of window screen over the back side (just wrap it around the edge and trim with a little overlap). The screen deflects about 85% of the blast and your plexiglass lasts a lot longer. The screen is almost invisible when your using the blast cabinet, you'll hardly know it's there. Frank
