Projects Belly Tank Build UK
Discussion in 'Traditional Hot Rods' started by JamieUC, Jan 3, 2021.
  1. JamieUC
    JamieUC
    from Swansea UK
    Back from Pendine after a fantastic weekend, got a good couple of runs down the sand in my coupe.
    Lots of very nice cars at Pendine this weekend but this one belonging to my mate Brett is one of my favorites, really inspires me to get mine finished for next years event.
    Jet96, Stogy, The 39 guy and 5 others like this.
  2. Little Terry
    Little Terry
    I really like your coupe. I gave it a real good once-over on Saturday in the pits. Very nicely put together by the look of it. Sounded nice going up the beach too
    Mark
    Stogy, loudbang and JamieUC like this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks for the vids.
    Nice race cars.
    Lovely race course too.
    How long is it?
    How long are the speed traps?
  4. Two very cool videos. I want to do that with my RPU too. :cool::cool::cool::cool: JW
  5. nunattax
    nunattax
    from IRELAND
    on the 2 do list,next year maybe!!
    Stogy, JamieUC and loudbang like this.
  6. Half a mile standing start, sixteenth of a mile trap.
  7. Sakke
    Sakke
    from Finland
    Thanks for updates and videos !
  8. JamieUC
    JamieUC
    from Swansea UK
    Cheers Mark, see your a Shropshire lad , I grew up not far from Shrewsbury, my stomping ground as a youth.
    Stogy, loudbang and Little Terry like this.
  9. bob miller 32
    bob miller 32
    from france
    hope to be at pendine ! not this year again . fucking covid
    Stogy and loudbang like this.
  10. trikejunkie
    trikejunkie
    from Scotland
    I saw your car at Pendine but only from behind a 7 foot high wire fence -very impressive.The only drawback was that as I couldn`t buy a pit pass all the cars were off limits!!!! I only had the day there so waiting until after the racing was finished and the cars were leaving to speak to the owners about their cars and even then it would have been impossible to follow each owner back to their caravan/tent /motorhome.It was a great day watching them though.
  11. roddering
    roddering
    from Arizona
    Amazing work!
  12. JamieUC
    JamieUC
    from Swansea UK
    Well got back to working on the belly tank this week, made some mounts for the front shocks, and a set of front racing discs. I cheated with the discs and cut them on my CNC, my business is fitting out camper vans so the CNC cuts all the cabinetry, but also does a very good job of cutting sheet aluminum, not a very traditional method but hey, jobs a good um.
    Tank76.jpg Got to add some screws, as thinking Dzus but I thing six screws per disc is a more traditional look.
    Also made up some dogbone links for the shocks but not fitted them yet, need to machine a couple of boss's for the axle to mount the dogbones/drop links.
    flathead 37, Tman, Stogy and 8 others like this.
  13. Those discs and shocks look great! Looking at your steering box, if you had a steering arm on the top of one of your spindles like i have the steering link rod would be near straight (flat) or at least not much of a bend to it. JW
  14. JamieUC
    JamieUC
    from Swansea UK
    After seeing your setup I ordered a droped axle steering arm that I will mount upside down on the top of the spindle so drag link should be nice and horizontal.
    Stogy, loudbang and 26 T Ford RPU like this.
  15. I tried doing that too but they don't fit because the upper king pin boss is much deeper due to the KPI. I had my one made for me that is 16 mm / 5/8'' extended to clear. You will need to space it out. JW
  16. JamieUC
    JamieUC
    from Swansea UK
    I didnt think that one through did I. Just looked and the upper boss is bigger, like you say some spacers should sort it out, Ive got to modify the arm anyway as I'm using 36 spindles so the bolt spacing is slightly different.
  17. I could get Drew to make you a custom one to your specs if needed, i'm sure the exchange rate would work well in your favor. $125 NZ each for me. JW
  18. JamieUC
    JamieUC
    from Swansea UK
    Been working on the steering, brought a quick release boss and machined up a addapter to fit it to the aircraft yoke, also did a center cap for the yoke.
    Turned up a steering shaft
    and colum all fitted.
    Super bell steering arm arived from the States today so hopefully get that fitted this weekend and measure up for the drag link.
  19. rpm56
    rpm56
    Outstanding fab skills.
  20. Looking good, Jamie. JW
  21. That wheel is perfect for your build!
  22. JamieUC
    JamieUC
    from Swansea UK
    Finally got steering, fabed up a drag link today
    All welded up and fitted, I'm not quite happy with the look so going to flip the rod end under the steering arm and heat and bend the pitman arm down a bit, this will make the drag link a couple of inches lower and paralle with the axle.
    Also welded up a push bar for the rear, real race cars get pushed off the line;)
    Jet96, flathead 37, 282doorUK and 4 others like this.
  23. The steering and push bar look great.... whats next? JW
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  25. They can point any direction.
  26. Juast had time to look at the whole thread. Nice work you are doing! I am also using a yoke for a wheel in my car. Mine is Beechcraft
  27. Marty Strode
    Marty Strode
    A buddy just picked me up a yolk out of DC- 3 / C-47. Perfect wheel for a Tank or early style Dragster. Great work ! IMG_7551.JPG IMG_7552.JPG
    Jet96, brEad, Blown Red Ram and 3 others like this.
  28. 28rpu
    28rpu
    No they can't. The officials frown on headers pointing down. I know from experience.
    HotRodWorks and loudbang like this.
  29. Never seen that rule enforced BUT most folks point them up or back to help with downforce or thrust
  30. JamieUC
    JamieUC
    from Swansea UK
    Going to focus on foot pedals and gear linkage next but might do a dashboard first, I've got some nice aviation gauges to go in.
    26 T Ford RPU and loudbang like this.
