Projects Belly Tank Build UK
Discussion in 'Traditional Hot Rods' started by JamieUC, Jan 3, 2021.
  1. JamieUC
    JamieUC
    from Swansea UK
    That sounds like it could work, just gotta figure some sort of bearing/bushing for the column to move up and down in.
  2. JamieUC
    JamieUC
    from Swansea UK
    Steering yoke is from a Grumman S-2 aircraft introduced in 1954 so just about right... should pass HAMB inspection:D
    Tman, AHotRod and loudbang like this.
  3. 282doorUK
    282doorUK
    Agree well done on the roll cage, very hard to get right by hand.
  4. Hotrodder28
    Hotrodder28
    Very nice Project!!
  5. nice job Jamie............
  6. marc billen
    marc billen
    from lakeside
  7. JamieUC
    JamieUC
    from Swansea UK
    Made some good progres with the roll cage this week, made a arbour to mount hole saws in my mill and set about fishmouthin.
    Works well, set up and clamping is a bit slow but it does the job.
    RatPwrd, AndersF, AHotRod and 10 others like this.
  8. Fabber McGee
    Fabber McGee
    I have had some success holding tubes together for tacking by running a loose loop of wire around the longitudinal tube and hose clamping it to the cross tube, then twisting the wire with a pair of pliers to tighten it.
    loudbang and AHotRod like this.
  9. You asked a bit ago of any progress pics, well i got one. JW
  10. JamieUC
    JamieUC
    from Swansea UK
    Thats a good idea I've done that with hose clamps and small angle brackets but with a bit of wire wouldn't need so many hose clamps.
  11. JamieUC
    JamieUC
    from Swansea UK
    Looking good you going all tube chassis? its reminding me of the Tom Beatty tank already. Have you decided on an engine yet?
    26 T Ford RPU likes this.
  12. Was always going to be a Willys 4 as im a Willys guy from the mid 70's. The one i got is a 46 Jeep motor. Main reason for the Jeep is the counter weighted crankshaft. It's 63hp standard and 134cid so it should be able to do something reasonable with a bit of a warm up. JW
  13. AHotRod
    AHotRod
    Great passion and talent, love your project
    26 T Ford RPU and loudbang like this.
  14. Yes, all the chassis will be tube as the SCTA states it can have no flex and must be rigid. I was going to do like you did but it was easier for me to go tube. I'm all fired up for more progress on mine and your 's is good inspiration.:cool::D JW
  15. myergin
    myergin
    Great work! I cant get enough of these belly tank builds. Maybe I'll be lucky enough to tackle one someday.
  16. Jamie, i started my own Build Thread a week ago.. the push is on! :cool::D JW
  17. JamieUC
    JamieUC
    from Swansea UK
    Good stuff, I will check it out.
  18. Fabber McGee
    Fabber McGee
    How about a link please.
  19. Belly Tank Build, NZ .
    JW
  20. Fabber McGee
    Fabber McGee
  21. Fabber McGee
    Fabber McGee
  22. JamieUC
    JamieUC
    from Swansea UK
    Have been real busy with work last couple of weeks so not posted much but been piecing the roll cage together, this rear section had to be fully welded as it butts up to the firewall so would have been neigh on impossible to weld once fitted.
    Got the main part of the roll cage all in now, still gotta do some leg protection and put a hoop in for the steering colum /dash mount.
    With the cage in place I finaly cut the front top section, think it looks mean even if i do say so myself.
    brEad, kevinrevin, X38 and 12 others like this.
  23. brepil
    brepil
    Looks stunning Jamie. I'm coming over to the Gower soon, I'll call in.
    loudbang and 26 T Ford RPU like this.
  24. That looks amazing and i didn't think the roll cage would be that low, that how i want mine. GOOD JOB!! JW
  25. JamieUC
    JamieUC
    from Swansea UK
    Cheers Brett, will be good to meet up, kettle will be on!
  26. JamieUC
    JamieUC
    from Swansea UK
    I wasn't sure if it would be low enough to run a canopy which is my plan, but looks like it will work fine.
    26 T Ford RPU, Besty34 and loudbang like this.
  27. Fabber McGee
    Fabber McGee
    Will the top front come off for entry/exit? Is the cockpit hole at finished size? I'm concerned about getting out if the skin gets wrinkled. I'm sure you have a plan.
  28. Damn that's kool Jamie.................
    JamieUC and loudbang like this.
  29. 51504bat
    51504bat
    What are the bailout requirements at tech?
    nunattax and loudbang like this.
  30. This is from the SCTA (2019) rule book so not sure of the requirements in the UK but i would think safety is safety wherever. Posted as many following here would not know. JW
    brEad, JamieUC and loudbang like this.
