1937 CORD BOAT TAIL SPEEDSTER ** REPLICA ** FROM THE FOLDER FULL OF RECEIPTS, IT APPEARS THIS BEAUTIFUL CORD REPLICA WAS A PROJECT STARTED IN THE LATE 2000’S IN FLORIDA. AT SOME POINT, IT WAS SHIPPED TO ANOTHER OWNER IN MAINE WHO MOSTLY FINISHED THE CAR… THEN THROUGH A TRADE, IT IS CURRENTLY OWNED BY A LOCAL COLLECTOR / ENTHUSIAST WHO IS ROATATING HIS COLLECTION. THE FRAME / CHASSIS AND RUNNING GEAR ARE FROM A 1977 ONE OWNER MERCURY GRAND MARQUIS. THE MOTOR IS THE ORIGINAL 460ci THAT HAD 17,000 MILES ON IT… COMPLETELY OVERHAULED – CRANE CAM W/ MATCHING LIFTERS, NEW RINGS, BEARINGS, PISTONS, HEADS- FLOW TESTED, CRANK BALANCED, HIGH FLOW (MELLON) OIL PUMP, NEW MOROSO HIGH FLOW WATER PUMP, PETE JACKSON TIMING CHAIN / GEARS, 3-ANGLE VALVE JOB, EDELBROCK ALUMINUM INTAKE- GASKET MATCHED TO HEADS, NEW CARB…ETC… CUSTOM MADE FOUR CORE RADIATOR W/ ELECTRIC PUSHER FAN ORIGINAL C6 TRANSMISSION REBUILT WITH B&M SHIFT KIT, NEW TORQUE CONVERTER… FORD 9” REAR, NEW CARRIER BEARINGS, NEW PINION BEARINGS AND AXLE BEARINGS… BRAKES / FRONT END – ALL NEW BUSHINGS, BALL JOINTS, ROTORS, CALIPERS, BEARINGS, NEW SHOCKS FRONT & REAR, ALL NEW REAR DRUM BRAKES, SHOES AND ATTACHING PARTS… NEW CUSTOM SIDE EXHAUST E/Z WRITING 12-CIRCUIT FUSE PANEL VINTAGE GAUGES POWER GM TILT STEERING ( ALL NEW HOSES, NEW PUMP, REBUILT BOX ) POWER HYDRAULIC TILT FRONT END GENIE SHIFTER ALL NEW CUSTOM LEATHER INTERIOR W/ BMW SEATS BILLET SPECIALTY STEERING WHEEL CUSTOM TONNEAU COVER LOCKABLE STORAGE BEHIND SEATS THE AMAZING, NEAR FLAWLESS BODY PAINTED IN A PERIOD CORRECT CORD TWO-TONE PAINT SCHEME. ACCENTED WITH CUSTOM RUNNING BOARDS, CUSTOM ALUMINUM BUMPERS AND CHROM ACCENTS. ALL WHILE ROLLING ON NEW COKER TIRES W/ WIRE WHEEL HUBCAPS… AS YOU CAN TELL FROM THE PICS THIS CAR DOES NOT DISAPPOINT !!! CLEAN TITLE THAT IS TITLED AS A CORD. ONLY 600 MILES ON CAR SINCE FINISHED. QUICK START UP AND WALK AROUND VIDEO: https://www.youtube.com/watch?v=aLNzNFwI2c0 FOR MORE PICS AND INFO CONTACT: JAY BROWN (302)-358-6657 [email protected] OR: AARON D. (302)-547-5004
