bead rollers *&^%$
Discussion in 'The Hokey Ass Message Board' started by heavy, May 17, 2006.
  1. heavy
    heavy
    anyone have ideas on making your own bead rollers:confused:
  2. T_rav
    T_rav
    it would be cheaper to buy one. they sell em that fit in a vice. beads come out good too.
  3. Chris P
    Chris P
    from Tucson
  4. hsheartaches
    hsheartaches
    A buddy's got one from Harbor Freight...we had to reinforce it to keep anything from walkin' in it, but now it's smooth as a rail....literally. heheh
  5. Pooch
    Pooch
    from Oklahoma
    How did you reinforce the harbor freight bead roller?
    Pooch
  6. poop
    poop
  7. hsheartaches
    hsheartaches
    We cut a 1/4" plate doubler out that was just a bit smaller than the original plate that hold the rollers, and did a partial pen weld all the way around.
    For instance, it looks like a U right?? So we cut a smaller U and welded it to one side. Works like a dream now.
  8. scootermcrad
    scootermcrad
    Can you swap dies on the Harbor Freight model? Also, the last time I went to HF's website I couldn't find the bead roller anymore. All I could find was the edger and a stand for a bead roller. did they discontinue it?? I hope not! I had plans of my own for that thing!
    Good stuff here! Metalshapers rule!
  9. hsheartaches
    hsheartaches
    Yup...$99 for the hand crank. The dies do swap out, and I believe they carry a die kit for it as well. It'll do 22-24ga w/ no reinforcement and do a good line. It's not bad on 20ga....but you put a piece of 18ga in it w/o reinforcing it, and it'll roll the "slipper when wet" sign. heheh It's a cheap and easy fix, or you can go out and spend $300 on a nice one. Just what I've found out.
  10. TINGLER
    TINGLER
    You could spend a week and $500 making one,
    Or you could buy a HF one for $99.
    I own a HF one.
    It works good for the hobbyist. If you're a pro...maybe get something better.
    I just wanted some beads in some sheet metal. It does that. I like it.;)
