Technical Battery box ideas needed
Discussion in 'Traditional Hot Rods' started by BruceNixon, Feb 16, 2019.
  1. BruceNixon
    BruceNixon
    See pic 31 coupe. I want to put the battery in the trunk with 10 gallon moon tank. I am building a new rear interior panel to mount tank and battery. Could you reply with some pictures or ideas on the battery box that will be built in to the rear panel, thanks
  2. F&J
    F&J
  3. johnold1938
    johnold1938
    from indiana
    get a pair of triple track drawer hardware and put the box in the frame under the car works great and does not interfere with the scrub line!!
  4. sloppy jalopies
    sloppy jalopies
    note the metal separators on each side, left side is the correct size for 4 quarts of tranny fluid...
    right side is for 3 quarts of oil...
    Went to goodwill,
    Bought 4 different size Tupperware boxes with lids, used the one closest to my battery size...
    Welded a flat washer on either side of the battery, to be located between the oil and tranny fluid storage... small ratchet strap ties down to them...
    Cut clearance slots for the battery cables and the ratchet strap to enter the Tupperware...
  5. mgtstumpy
    mgtstumpy
    Vanness and clem like this.
  6. Mr48chev
    Boat battery boxes are rather inexpensive, have passage ways for the cables and normally come with the tie down straps and retainers for the floor included.
    Another option, a battery size vintage looking cooler that is securely held down.
    A wood box that looks like a tool box is another one. Even a metal tool box the right size.
    mgtstumpy likes this.
  7. fordrodsteven
    fordrodsteven
    I know a guy who moved his battery to the trunk. He used a plastic box that the battery fit in pretty good. He told me it was a Tupperware box he picked up at a yard sale for $2.00. He fashioned a strap that bolted to the floor and went over the top to hold the lid down and hold the box in place, He drilled a couple holes for the cables and also put a vent on it that fed out through the front of the trunk and above the rear end.
  8. raven
    raven
    I used an ammo can for my small Optima battery. Welded the base recessed into the floor and cut holes for the battery cables. Lid on the top still fits.
    r
  9. 5window
    5window
    My tank's in the trunk-16 gallon Tanks rectangular. The battery is on a tray under the car,forward of the rear axle, with jumper ports on a panel near the running board. Not the most convenient, but clean and so far, OK
  10. Vic Walter
    Vic Walter
  11. sunbeam
    sunbeam
    Check out the ones they sell for boats unless they are vented outside you wont like what happens to your trunk
  12. 56sedandelivery
    56sedandelivery
    Check out the ones a HAMB member sells in the classifieds here; custom made, riveted together, polished aluminum.
    I am Butch/5t6sedandelivery.
    oldsjoe likes this.
  13. The sealed boat battery boxes are a fast, inexpensive answer, as many have posted. But if you don't want any plastic in or on your rod, then any of the other suggestions will be more "nostalgic" looking. Depending on how finished off the trunk area will be, I've seen vintage luggage used to cover up everything from subwoofers to suspension intrusions.
    I keep busy in my retirement with a traveling car show booth where I sell survivor and refurbished shift knobs and accessories. I'm working on a couple of old doctor's leather medical bags at the moment. My idea was to promote them as cool tool kit bags. The larger one would easily hold an average size battery. Look around with your imagination cap on and you're bound to find something that's special to you.
    Edit to add: I think I was trying to get around to saying...... "You can do the boat box and cover that with something old-ish in keeping with the car."
    pitman and oldsjoe like this.
  14. Bam.inc
    Bam.inc
    from KS
    Lots of good ideas, build it or buy it.
    I've been looking for same idea, but not there yet. Screenshot_20190217-160254_Chrome.jpeg Screenshot_20190217-160131_Chrome.jpeg Screenshot_20190217-160039_Chrome.jpeg
  15. sloppy jalopies
    sloppy jalopies
    On a '34 convert I was working on I set up a cage with 2 tab slots at the front of the trunk floor...
    built a battery tray that slid forward with its tabs locking in the trunk's slots, then a tie down bolt at the rear of the tray...
    it let me slide the tray back towards me... lets me take the battery out without killing my back...
    built a small tool box to protect the battery terminals, mounted it on top of the cage... no pix.
    ... my $0.02 .
  16. lilmo630
    lilmo630
    I have a model a sedan, the battery is located under the front passenger seat. The seat is hinged to flip back for access to it. The steel box was custom made and mounted to the inner frame rail.
  17. 5window
    5window
    Looks like neat work, but I am not sure how comfortable I'd be driving with along with a fuel tank sitting next to an electrical spark source in my enclosed space. At the very least, I'd want a steel "firewall" between the trunk and the cab. And, a fire extinguisher.
  18. pitman
    pitman
    Them floor-based 'breather-hole' gaps and no gasket round the trunk lid, aerate just fine. :) FWIW, keep movin!
  19. Maicobreako
    Maicobreako
    I once bought a boat that the PO had used an old milk box for the battery box . Now my wife has it on the porch as decor.
    LBCD and Latigo like this.
  20. Latigo
    Latigo
    When in high school I worked a while at a small manufacturing company and made hundreds of those milk boxes. Boring work but paid for the gas for the 55 Chevy. Haven’t seen one in years. Thanks for posting.
  21. 5window
    5window
    Bruce, you don't say where you are located, but it would be a good idea to check if a fuel tank in the trunk is legal in your state, if you're in the US. Second, unless I missed it, you'll need a vent on that tank and it should be a "roll-over" vent. Third, you should have a real "firewall" between your tank and the seats. There is no good place for a gas tank in an A coupe, but you can make it safer.
    alanp561 likes this.
  22. LM14
    LM14
    from Iowa
    9300B098-B811-4701-A84F-9D8450333652.jpeg AA5DAE6B-71B0-4FA8-A1AD-04C04ABF0FDD.jpeg C91B0671-9D3E-4FC4-8165-1C6C75290E0A.jpeg 44CBF9ED-1B4A-47EC-B0C8-460B86FB90CA.jpeg 8AD81FA8-0947-4CA5-9B9B-41DECE064B26.jpeg 6078FA64-ED08-4985-8202-8D6619B4776E.jpeg F285DAB3-0611-47B6-BF5E-5251D7EF86FA.jpeg F4F64952-6311-4AE6-BCE9-0DFCB3D64718.jpeg B33FB290-16EB-4BFF-B937-76AF5FF70347.jpeg My solution.
    waxhead likes this.
  23. kabinenroller
    kabinenroller
    Here is my solution. Not a tool box. It is a circular saw box with the bottom cut out. The back panel has a section removed, the cables are routed through a separate panel that the box slides over. This allows the battery to be serviced thought top cover or by removing four button head screws to remove the box completely without disturbing the battery or it’s connections.
    There is a vent hose on the back panel that runs outside the body.
  24. Ralph Moore
    Ralph Moore
    I just found this old military fuel tank, was for diesel, made a few mods to it and it works great. I do plan to put a divider once I install my package tray.
  25. Here's what I built for my 32...make sure you vent a roll over check valve in your moon tank install..
  26. 24 Dodge
    24 Dodge
    Check out the ones I make Aircraft Style Riveted and I can put Louvers in the top if you would like. They are sold in parts for sale in the Classifieds
