Barn Find, Ford 427 dual quad top end
Discussion in 'The Hokey Ass Message Board' started by Lazlobassett, Dec 9, 2010.
  1. Lazlobassett
    Lazlobassett
    Well, I was poking around in an old barn and found a dual quad set up. Seems to be 1965 427 ford from a Galaxie. Its all there, factory carbs, linkage, fuel log, heads, exhaust manifolds, vintage Mickey Thompson Headders, Finned air filter cover only, base is somewhere...
    I'm not a Ford guy but know this isn't stuff one comes across every day, heck I've been digging around for years and hadn't seen this before.
    Anyone have an idea of what this stuff is worth? it will all need work but isn't in bad shape. I wish I had my camera, be a cool picture to see this stuff in amoungst leaves n stuff in a shed with half a roof... My eyes sure lit up !
    Cheers!
    Matt
  2. At least a grand to the right guy I'm sure.....
  3. 69tincanfairlane
    69tincanfairlane
    from UYA
    I bet those headers would go for big money by themselves, especially if they're M/T "Super Scavengers".
  4. snap too
    snap too
    from lost wages
    I have to ask if those heads and intake are "Tunnel Port"
  5. Lazlobassett
    Lazlobassett
    Those are the carbs in the picture from Swade41, I poked around on FLEAbay, the stock exhaust manifolds are there with asking prices of 1200 to 2200, not sales, asking prices. there was a dual quad set up but it looked to be missing things, not sure about that.
    The headdders have different lenght pipes inside the collectors to equalize the individual tube lenghts, I've not seen that before. they look to be hand fabricated.
    Very interesting stuff. I'll try for some pictures
  6. Lazlobassett
    Lazlobassett
    I'm not sure about if they are " tunnell Port" the intake isn't a high rise...
  7. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    Best do some diligent research. 2x4 were made for all kinds of specific apps. some are worth a buttload of money, some not so much. the exhaust sounds intrigueing. get some good pics up, it'll really help you out if you're not 100% on i.d.
  8. SOHC427
    SOHC427
    Post up some part numbers off the carbs and intake, and I will see if I can help,
    Eric
  9. 69tincanfairlane
    69tincanfairlane
    from UYA
    By that description... those are M/T "Super Scavenger" headers... those are rare especially if they're for a Ford!
  10. By your description the headers are M/T super scavengers.
  11. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    didn't one of the big names in superstock, Galpin maybe, use those?
  12. OoltewahSpeedShop
    OoltewahSpeedShop
    FE guys are nuts (in a good way). That stuff is worth a small fortune, to the right guy. Part numbers mean EVERYTHING! 427 stuff is better than Gold! Tunnel Port stuff is the holy Grail, but basically un-driveable in a street engine. Huge intake ports! That doesn't change the fact that they bring BIG BUCKS.
    Do some research and describe your parts correctly.
    Good luck.
    Kevin
  13. To check it they are tunnel port, just look at the ports in the intake or intake side of the head. If they are oval you're in the money.
    I have a pair on my 427 and want another if you're sellin'.
  14. I'd say look around a bit more. If there is a block there with bolts holding the main caps in thru the sides -- then get excited.
    From what you have posted it could be anything from a Lowrise 427 to a Medium or Hi-Rise one depending on casting dates. Meduium & Hi-Rise manifiolds are worth more. Tunnelport manifolds are unusual to find but you would then require TP heads to make it work but are worth alot more.
    Still the setup is worth a minimum of $800 to $2200+ FYI Bare 2X4 LR manifolds are worth $400-600.
    Only my veiwpoint & I'm cheap.
    Movin/on
  15. Lazlobassett
    Lazlobassett
    Thanks for all the information, I have a few days before I have to go back to real work. I'm going to try & get round there and see if I can make a deal.
    The guy bought the 427 new in 65 in a galaxie, raced it for a couple of years then put it into a '64 comet. It chucked a rod he got stuff to put it back together, wrapped it all in plastic bags and there we are 30 years later.
    there is also mention of a " rock Crusher " 4 speed which I have never heard in reference to a Ford trans ? and a cast steel blow proof bell for the same...
  16. Lazlobassett
    Lazlobassett
    Block is gone, caps are there and yes they have the bolts through the sides.... Guess i should make a point to gather them too?
  17. shoprat
    shoprat
    from Orange, CA
    Put up some pic. Maybe a Tunnel Wedge, my favorite.
  18. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    just get anything made of ford metal! there are things like the metal screw-together fuel filter and goofy bracket, hardlines, balancer etc. etc. just get it all!
  19. Black Panther
    Black Panther
    from SoCal
    Man I would look over that guys place with a fine tooth comb...if he has that rare Ford stuff he is liable to have a lot more...
  20. Bruce Lancaster
    Bruce Lancaster
    Yeah...anything small. All of the brick-a-brack like lines, filter, linkage, etc. is unique to a very small range of cars, and can be insanely valuable because it was generally tossed early in the car's racing career.
  21. 51 Hemi J
    51 Hemi J
    Grab a camera and get some pics Already! :D
  22. FE guys will even buy the broken stuff.I have sold rusty side oiler blocks with the sides broken out and he was excited to get it.
  23. SOHC427
    SOHC427
    FE Guys are pretty hard core, plus the stuff works! I had 390's 428's and SOHC's, and loved them all. Multipul carbs are the bomb, too!
    Eric
  24. BOWTIE BROWN
    BOWTIE BROWN
    better then a 401k.
  25. why does this sound sooo familar ?
  26. OoltewahSpeedShop
    OoltewahSpeedShop
    No doubt... FE stuff will keep a fat stack in your pocket. You gotta know what the numbers mean though.
    Aftermarket FE parts are VERY available. Don't kid yourself into buying this stuff to re-sale. Waste of time and money.
    The C parts are GOLD.
  27. Lazlobassett
    Lazlobassett
    "C" parts? This stuff is all original genuine Old Stuff, I've no doubt about that.
    Today is pick up day, the deal is done and I'm going to root through the piles, should have pix up tonight!
    Cheers!
  28. cide1
    cide1
    I have heard people call the Muncie M22 a "rock crusher" due to the larger cogs on the gears compared to a M21.
    /Coming from a chevy guy...
  29. Chevy55
    Chevy55
    from Nebraska
    I will be interested to see what the trans actually is. Most likely a top loader Ford coming from a Ford parts stash. The angle of the gear cut on a "Rock Crusher" was designed to give it more tooth contact and causes it to make more gear whine hence the name. Post the parts pics!!!!
