Technical Bare Metal Wet Shop
Discussion in 'The Hokey Ass Message Board' started by Clik, Jan 17, 2019.
  1. Clik
    Clik
    I have a bunch of metal work to do and the panel truck will be in bare metal for awhile. I have no way to heat or dehumidify the big barn. All I can do is keep the rain off. When temps change everything sweats. Any options to stop flash rust for the (realistic) months it may be bare metal?
  2. deathrowdave
    deathrowdave
    from NKy
  3. Anything you put on the metal, gibbs or primer will have to be removed before painting in the future. Having worked in a barn and spraying lacquer primer as I went a few years later I learned the primer didn't seal the metal.
    Before I got around to painting the rust was starting to bleed through the primer. HRP
    Boryca and chryslerfan55 like this.
  4. john worden
    john worden
    from iowa
    PHIX is excellent. It contains phosphoric acid and doesn't contaminate the metal.
    oj and blowby like this.
  5. BigChief
    BigChief
    Gibbs. ALL. THE. WAY. Respray every couple of months. When its time to paint Gibbs cleans up nice....has a tendency to creep into seams....but, bizarrely, doesn't come back to haunt you.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  6. eaglebeak
    eaglebeak
    Gibbs says you can paint over it.
    Happydaze and gimpyshotrods like this.
  7. Hollywood-East
    Hollywood-East
    I'm an epoxy person myself, painting for 35 yrs. I don't care what anyone says Oil an automotive paint is nothing I entertain.. jmo
  8. gimpyshotrods
    gimpyshotrods
    I regularly paint over surfaces that have been treated with Gibbs. I have been doing so for about 25-years.
    I have never had a single issue. Not even one.
    So, you have a choice: You can trust speculation, or you can trust actual experience.
    mkebaird, King ford, Bam.inc and 3 others like this.
  9. Vics stuff
    Vics stuff
    I would use ospho on he sheet metal
    Vic
    VonWegener and oj like this.
  10. I used Gibbs on my car and it sat in several shops for 10 years. I wiped the car down with lacquer thinner before I applied epoxy primer sealer and I'm sure I missed a few spots when I wiped it down...didn't matter. The epoxy primer adhered perfectly with no lifting or wrinkling. Love that Gibbs! And use primer/sealer like epoxy primer.
  11. choptop40
    choptop40
    Holy mackeral , that's some good stuff right there....
  12. oldolds
    oldolds
    Personally I would make the body all bare metal. Epoxy prime it. Do the metal work as needed. At the end of the days metal work I would use a quality spray can primer such as Sem or U-Pol to cover the bare metal. When the panel is done being metal worked remove the spray can material and spray on good epoxy or what ever you usually use as the starting point of your paint job.
    I understand your problem and concerns with the metal sweating with temp changes. I would not want to be bothered with re-applying oil every month or so. I have cars and parts stored in barns and this summer with the amount of rain we had in the northeast the concrete floors in the barns were wet from condensation all summer. To the point there were puddles on occasion.
  13. two couped up
    two couped up
    from pa.
    I get epoxy on everything also then repair panel by panel to the point that it only needs sanded sealed and painted. I use the weld thru primer as I repair the spot, and you can paint over it with out problems. I'm not working in a barn but I don't heat my garage unless I'm working out there, and the temperature change can flash rust metal here in western PA. over night.
  14. john worden
    john worden
    from iowa
    Oil will certainly seal metal from rust as long as it is reapplied as the oil evaporates.
    Phosphoric acid drys and doesn't evaporate. Plus it is actually recommended for use in the paint prep stage.
  15. 49ratfink
    49ratfink
  16. AngleDrive
    AngleDrive
    from Florida
    I use Picklex 20, expensive, looks like ospho but much better. Keeps sheet from surface rust for 6 to 12 months and my shop is damp most of the time.
    KoolKat-57 likes this.
  17. Clik
    Clik
    Since I can't spray epoxy in this cold weather it sounds like Gibbs is my best bet. What chains carry the stuff?
    gimpyshotrods likes this.
  18. reagen
    reagen
    Keep a fan blowing over the body it helps .
    classiccarjack likes this.
  19. 6sally6
    6sally6
    Flea Bay for sure..........ck Amazon and let us know.
    6sally6
  20. It's sold on the HAMB classifieds here...Search for "Gibbs" Its the real stuff and sold by a HAMB'r
    I've never found it in stores ...always had to order it.. And , beware of knockoffs online !!
    BTW : Its a great product
    The37Kid likes this.
  21. Clik
    Clik
    Yeah, I keep a fan circulating 24/7 for the shop in general. I've had some success with hanging a drop light in a car too. Just a little temp rise can eliminate sweat in some cases.
    reagen and BigChief like this.
  22. Clik
    Clik
    I found a sport shop near me that carries it. Will go there tomorrow.
  23. Clik
    Clik
    It looks like part of the ingredient in Gibbs Oil is light mineral oil. I'm not sure what the other ingredients are. I'm not sure why it's so expensive other than hype.
  24. Dino 64
    Dino 64
    from Virginia
    Walmart has it the cheapest
  25. blowby
    blowby
    from Nicasio Ca
  26. gimpyshotrods
    gimpyshotrods
    Hype is defined as excitement generated over something that may, or may not be what it is claimed to be. This product is what it says it is.
    It is more expensive because someone did all of the research and development into the proper ingredient formulation that produces the desired results.
    If you can pony-up all of the cash required to come up with a uniquely functional product, that has yet to be duplicated, you too can charge whatever you want.
    The rest of us get to buy it, and many of us do, by the case.
    That's basic Capitalism 101.
    mkebaird, ABONES and Just Gary like this.
  27. rustymetal
    rustymetal
    Picklex 20 used it a lot and it does work
  28. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I sent all the bare metal 32 roadster pkg cars I built out the door with a light wipe of Gibbs. Never had any negative feedback about painting from the buyers.
    Bam.inc and Just Gary like this.
  29. Clik
    Clik
    Cool. I never thought of checking Walmart.
  30. Clik
    Clik
    Sounds good.
