I have the opportunity to buy a 39 mercury rear end, is it different than the 39 Ford rear end and how would I know? Sent from my iPhone using The H.A.M.B. mobile app
Pretty sure those years the driveshaft is the pinion. Like the driveshaft doesnt disconnect from the rear end. All one piece, unlike ford that has a removable driveshaft. Sent from my SM-G977U using The H.A.M.B. mobile app
Yes both rear ends have a torque tube (enclosed drive shaft) I was just wondering if they were the same width and length? Sent from my iPhone using The H.A.M.B. mobile app
We mean the driveshaft is attached to the pinion gear. You can't change the driveshaft (length) easily, like you can a Ford.
Pretty sure the frames are wider on the Merc compared to a Ford, as is the front suspension. Don't know about the rear end.
I believe the width is the same but that pinion/driveshaft will make it extremely hard to shorten. Would be better off finding a Ford rear. Sent from my SM-G977U using The H.A.M.B. mobile app
