BANJO interchangeability
Discussion in 'The Hokey Ass Message Board' started by devotion, Dec 12, 2012.
  1. devotion
    devotion
    from idaho
    Will the backing plates and everything from a 48 banjo rear bolt up to a 35 banjo by chance?
  2. mlagusis
    mlagusis
    Not sure but check out Hot Rod Works webiste for a lot of banjo info and parts too. They are in Nampa too.
  3. MERCURYGUY
    MERCURYGUY
    I know that 42-48 passenger are innerchangeable. Also 35-41 frames are basically the same. Try an inquiry to Speedway Motors. I bet they can tell you. Tom
  4. carmuts
    carmuts
    I am thinking you have to use a 1/4 spacer to make it work. I could be wrong. Bolt pattern size should be the same from what I have read. Rod
  5. devotion
    devotion
    from idaho
    Anyone know if I can use the shorter axles and housing off the 35 onto the 48 center?
  6. 19Ardun46
    19Ardun46
    Yes... The 32-48 banjo housing is the same.
  7. 19Ardun46
    19Ardun46
    I forgot to add, the spider gears are different on the earlier rear ends, so you have to have the correct combination of those parts also to make the swap work.
  8. Bruce Lancaster
    Bruce Lancaster
    On axle interchange '35-48, the only limit is that you need to keep the right set of spider gears for the axles. Tooth counts changed about 1938, the inner differential case is tha same for all so you can just transplant the gears (be sure case is kept aligned as original). Also, you can find matching length axles for the commones size in both tooth counts. Axle tubes, backing plates, etc., no problems.
    Remember that the side gaskets adjust preload and mesh, so measure their thicknesses and match those assuming you keep same inner case and bearings.
  9. 117harv
    117harv
    The banjo housings, the center section, are smaller in width from early 32-34, 35 and up are the same. Early 32 with round flange is the same as model A.
  10. h.i.
    h.i.
    from denver
    I thought the 42 - 48 were wider than the earlier ones?
  11. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    Hot Rod Works is now making the kit to put the earlier 1932-1934 bells on the 1935+ center section. it's a neat way to keep the narrow bells and have the strength of a later V8 center.
  12. chopt top kid
    chopt top kid
    Here you go!!! double click on the pic's to make them big enough to read...
  13. h.i.
    h.i.
    from denver
    Nice. Thank you!
