Technical Banger with BB bell housing for T5
Discussion in 'Traditional Hot Rods' started by barrnone50, Apr 30, 2019.
  1. barrnone50
    barrnone50
    from texas
    Gathering parts for a T5 Conversion.. Is there any issues using a BB bell housing. Any help
    would be thankful.
  2. I wasn't aware that there is any difference between a big bloc and small block bellhousing?
  3. Kiwi 4d
    Kiwi 4d
    Appreciate the humour, i think the OP means a 1932 model BB 4 banger bell housing ,as his title says “banger”.
  4. brokenspoke
    brokenspoke
    BB one is the correct one to use
  5. IronTrap
    IronTrap
    I have a BB bell housing and the T5 adapter in my stash if you need them. Shoot me a message.
  6. Model A Gomez
    Model A Gomez
    I had an AA bell housing with an aluminum plate adapter and it fit fine, didn't end up using it because it put the shifter too far back with the S10 T5. Used a 32 case and V8 gears with a stock rearend, worked fine but no overdrive.
