Technical ***Banger Thanksgiving: November 2014 Banger Meet***
Discussion in 'The Hokey Ass Message Board' started by Jiminy, Nov 2, 2014.
  1. Bluto
    Bluto
    Bill Thank you I will not go easy
  2. Crap,
    just found out another friend of mine had a stroke last weekend.
    Hang in there Bluto!!
    John
  3. Crazydaddyo
    Crazydaddyo
    Jim,
    Hang in there. We need you around here.
    Maybe this will get you breathing hard.
  4. noboD
    noboD
    Listen to your nurse/boss.
  5. Hang in there, Jim!
  6. Bluto
    Bluto
    Craz......
    You haven't met Mrs Bluto ..... her smile is the best medicine I have.
    She is a wonderful nurse. And my best friend
    Thanks all you guys
    BCCHOPIT and Crazydaddyo like this.
  7. BCCHOPIT
    BCCHOPIT
    Thanks for all the hill climb info guys...
    WACCUSTOMS.COM
  8. BCCHOPIT
    BCCHOPIT
    Get Well ASAP Jim!!!!
    WACCUSTOMS.COM
  9. ebtm3
    ebtm3
    Jim-
    1 Listen to the Docs
    2 You have Z, better than meds.
    3 We're all praying for you buddy.
    Herb
  10. RussTee
    RussTee
    Take care Jim we need you present and correct
  11. Bluto
    Bluto
    Please lets go back to talking motors ...... even though much of it is about Fords o_O it's better than talking about me
    Good night from the eastern front
    BCCHOPIT likes this.
  12. Crazydaddyo
    Crazydaddyo
    OK. This was at the FAST hillclimb on Sunday:
    A block, 4" stroke 4" bore. 3 valve DOHC. Blown and injected. I was told that the rods are shorter then stock and the head is inset into the cylinders quite a bit. Runs up to @ 6500 rpm.
  13. BCCHOPIT
    BCCHOPIT
    My only banger fun was making this intake this week. But I don't get to keep it. ImageUploadedByH.A.M.B.1415419950.124104.jpg
    WACCUSTOMS.COM
  14. 64crump
    64crump
    from Alta Loma
  15. 64crump
    64crump
    from Alta Loma
    A little late, but hey here are more photos from last weeks F.A.S.T. hillclimb in Murrieta
    IMG_3082 (640x480).jpg IMG_3100 (640x480) (2).jpg IMG_3102 (640x480).jpg IMG_3103 (640x480).jpg
  16. 64crump
    64crump
    from Alta Loma
  17. 64crump
    64crump
    from Alta Loma
  18. 64crump
    64crump
    from Alta Loma
  19. 64crump
    64crump
    from Alta Loma
  20. RussTee
    RussTee
    Tech info required ? I belive that with my Rutherford overhead with its large intake and exhaust ports that smaller venturi carbs are required in order to speed up airflow the extractor I am using will bea two into two into one system primary pipes being around 24 inches long secondary being around 18 inches has anyone any idea what the ideal pipe diameter should be? I know it will make little difference on a motor like my B but if I dont at least try and get each step right I am going nowhere. This is the kind of question that Bluto may be able to help out with that is if you dont mind Jim and feel up to it or Bill you work in this field. Airflow is what it is all about with these engines and it is not my strong point many thanks Rusty.
  21. Bam.inc
    Bam.inc
    from KS
    You fellas are BANGER CRAZY!
    Subscribed. Keep posting videos. These are so cool.
  22. Crazydaddyo
    Crazydaddyo
  23. Bluto
    Bluto
    I had a buddy that built flow benches out of Sears Craftsman shop vac motor. I had a bench of his. 18 inches of water. and you plugged it in the wall! The biggest factor was the tube matrix bundle. Tried several before he got it right. This was 1970 I think.
    My guess is that you can effect the ports with the correct configuration of various tubes and IDs
    I did find out that exhaust design is a "slippery slope" trial and error. Most designs are the result of pipe organ tuning not engines. I build and listen. If you get it right there is an "on the pipe" note change. Always used a megaphone in the pipes end. When you got it right the megaphone would begin to crack and fall apart. I'd fix them over and over....... so much so we had one we called "FRANKENPIPE" it was that stitched-up
    Hey brain still works. Tremors make typing a little hard to do. I hope this helps Please remember I am living on some pretty strong meds. Can't have anything sharp.
    I think you can effect flow by creating an intake port insert but you'll have to see yourself.
    And perhaps a less that radical lift or duration cam with 11l-112 lobe centers.
    I've read this over several times if it sounds goofy I'm sorry
    You can fix it all with a blower!:cool:
    gwhite likes this.
  24. RussTee
    RussTee
    Not goofy at all Jim blower yes but am trying to hold this thing together for as long as I can
  25. Bluto
    Bluto
    You don't have to put a blower on KILL!
    I honestly thought you'd gotten Fords to work pretty good.
    I wish I still had my flow bench....... It taught me how much I didn't know
    I'm trying to get back to my Rosengart(French Austin 7) engine. I'll post some of the itty-bitty go fast and make it live parts.
  26. Stovebolt
    Stovebolt
    Jimsky - go easy go well go get back to 4/4.
    take care.
  27. Just got home from ElMirage.
    Made two passes, 140.5 and a 141.2 mph.
    I need to look at data and see if maybe any more can be gotten out of this head.
    It may be better to just finish up the new one and forget this one.
    J
  28. Bluto
    Bluto
    John
    You do know how hard it is to go fast at El Mirage.....
    Maybe it's best to save this head and build another just in case you have the correct B'ville setup
    Just a thought
  29. jerseyboy
    jerseyboy
    Bill,
    Looks good! I see you've got the Willys in there.:D I am going to have to stop by and chat.
  30. BCCHOPIT
    BCCHOPIT
    The axle should be back this week from chrome I will call you when it's in. There a banger header and another intake in the works also.
    WACCUSTOMS.COM
