Banger Coupe Re-birth
Discussion in 'The Hokey Ass Message Board' started by D Staig, Mar 13, 2011.
  1. D Staig
    D Staig
    Thought i'd post up some pics of my Model A coupe i've been playing with for the last year or so...
    Bought this car from Northern California. I was told, and have no reason not to believe, that it had been in storage since 1959.
    I don't have a workshop at home, so a friend of mine generously offered me some space at his place of business. Thanks Leon!
    The car was in great condition when i got it The motor was missing parts of the distributor and carb, they were soon replaced and rebuilt, sump was removed and bottom end inspected, head was removed and cleaned and i did a 12 volt conversion with a 60's era generator. Mechanically everything else seemed ok, although now that i'm driving it the clutch/gearbox doesn't sound too well.
    (Question; with a stock running gear what speed should i be cruising at??)
    This first pic is after i had a new spring made to bring it down 3 inches in the rear.
    The wood kit up top was done for so i machined up some new bows, sides and the front piece out of some American Oak i had lying around.
    After getting the car running, i decided to remove the fenders and running boards...and then i started looking at the paint. It had been given a brush job at some point, but it had not stuck to the original paint very well at all, it was pretty much just flaking off. Got the pressure washer out and gave it a squirt.
    Fast forward a couple of weeks and i had the car back to original paint. It took way longer than expected to get paint removed from the swage lines and other hard to get bits. I do like it though...
    Finally, i painted up some 35 wires with 7.50's on the rear and 5.50's on the front. The steelies were just on there with spacers...its still mechanical brakes so the wires mated up to the drums the way they needed to. I also mounted some original guide light on top of some headlight stands i made out of a model A headlight bar. Also mounted some '37 tail lights and the number plate underneath the body at the rear.
    Just havin' fun doin whats already been done:D:
    Hope you like it!
    Dave.
  2. 29ToyA
    29ToyA
    Cool! Good looking project.
  3. partsdawg
    partsdawg
    from Minnesota
    Looks like a great start! Thanks for sharing and keep us updated.
  4. olskool34
    olskool34
    I love it! That original black paint was well worth the effort in my opinion. I have been tinkering with taking off my fenders and your coupe might be my inspiration. Diggin it man.
  5. brady1929
    brady1929
  6. Thought it looked bitchin in the first shot with the fenders but you can't go wrong either way.
    Sweet ride.
  7. 32fordroadster
    32fordroadster
    from Wisconsin
    Great looking coupe, far better shape than the one I started with. Have fun with it.
  8. Dave Mc
    Dave Mc
    Cruising speed according to Henry was 47 mph,after that it'll have it's tongue hangin out. big tires might give ya an extra couple mph'z,most likely rear gear ratio is 378
  9. D Staig
    D Staig
    Thanks...I'm not getting that much at the moment...might have to play with it a little.
    Thanks for all the positive comments fellas, glad you like it!
  10. ironandsteele
    ironandsteele
    i love it! looks a lot like mine too..
  11. BCCHOPIT
    BCCHOPIT
    Nice look-in ride...
    have fun with it
  12. youngrodder1929
    youngrodder1929
    from Vancouver
    Super cool coupe !! Deffanty worth the time of taking it back to original paint love it with out the fenders
  13. Stovebolt
    Stovebolt
    Dave,
    It looks as though you're ready for the dirt drags at the Chopped Hot Rod weekend ;)
    BTW - where did you get the rear spring modified?
  14. HeyyCharger
    HeyyCharger
    How awesome!
    Exactly what I'm planning to do also...
    Looking forward to seeing you line up at the CHOPPED dirt drags!
    HC.
  15. RoddyB34
    RoddyB34
    that looks great ,get yourself a 32-36 axle for the front to get it down an inch and a half ,some 32 perch pins and you can use your mechanical brakes still ,just done this on my sons 28 coupe ,,ditto on the rear spring mod,,,ours is a bit high P9171173.jpg
  16. HELLVIS
    HELLVIS
    i liked it better with the fenders
  17. D Staig
    D Staig
    Just went through the points and timing, and cruised comfortably at 75kph. Stoked!
    I got a new spring made at Carrolls in Campbellfield, took the og one in for reference, was shooting for a 4 inch drop but it came out at around 3.
  18. A BONED
    A BONED
    Cool ride amigo!
  19. Stovebolt
    Stovebolt
    Thanks for the info on the spring. Did they make a flatter main leaf, or just reverse the eyes?
    I'll give them a ring :)
  20. modelAsteve
    modelAsteve
    Good start! Remember you need a spacer to correctly mate the mounting surfaces of the late wires to the A mechanicals
  21. Goodlife
    Goodlife
    x2!
  22. D Staig
    D Staig
    Thanks mate...don't know about the dirt drags...gotta baby the gearbox enough on the street!
  23. D Staig
    D Staig
    Just a flatter main leaf. The leaf stock is wider though, be prepared to take a couple mm from each side where it sits inside the crossmember.
  24. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    At first I was like what the fuck is he doing?.....but then after seeing the end result I am on board. Definitely digging the new look!!!!
  25. firerod
    firerod
    from Colorado
    Great looking car!
  26. Rock and roll Dave................!!!!!!!!!!!!!
  27. thommoina33
    thommoina33
    Alliance Member
    from australia
    you need a spacer to mount early wires(35)to late drums.
    i just fitted 33 mechanical front brakes to my A with 35 wires,no spacer needed.
    btw,neat car,i'll have to line you up on the dirt at chopped.
  28. RoddyB34
    RoddyB34
    Looking like theres gunna be a plague of A coupe bangers at Chopped this year ,,,,cant wait ,,,,
  29. HeyyCharger
    HeyyCharger
    Damn Tom!
    That thing is NUTS!!
    Love it.
    HC.
  30. tunram2quad
    tunram2quad
