Technical ball end of wishbone
Discussion in 'Traditional Hot Rods' started by twostickmutt, Apr 4, 2021.
  1. twostickmutt
    twostickmutt
    Does anyone know how far can the ball end of the front wishbone can be pulled down after unbolted with jack stands under the frame rails not the front axle . thanks.
  2. clem
    clem
    I guess any movement is actually twisting the spring and shackles in ways they don’t like.......
    An inch or six would probably be achieved without any adverse effects, but the question would first need to be answered:
    Why ? and on what type of vehicle ?
    dana barlow likes this.
  3. sloppy jalopies
    sloppy jalopies
    caster / camber angle should remain the same as stock...
  4. twostickmutt
    twostickmutt
    Clem it's to see if i can get the trans pan off of the turbo 350 that's in it until I get around to splitting the wishbones. Nothing permanent. its a 39 deluxe coupe. THANKS.
    clem likes this.
  5. adam401
    adam401
    On my 34 I can easily pull it down 6 inches and Im sure I could pry it down further
    alanp561 and twostickmutt like this.
  6. twostickmutt
    twostickmutt
    thanks adam
  7. Dooley
    Dooley
    from Buffalo NY
    Yes as Adam said I have done the same to change my transmission pan.
    Pull down by hand and use a 2 by 4 between your wishbone end and frame.
    Splitting mine right now to eliminate this in the future.
    lothiandon1940 likes this.
  8. twostickmutt
    twostickmutt
    Thank you dooley . Are you using a kit from someone ? Would like to see a pic when you're done.
  9. Dooley
    Dooley
    from Buffalo NY
    Using the one from Pete and Jake’s, the Pete and Jake kit uses the original trans mount holes as a guide.
    Axle is out and ready to cut the bones. Need to replace the pan on the trans as well.
    I’ll snap pics
    lothiandon1940 and twostickmutt like this.
  10. Rickybop
    Rickybop
    from Michigan
    I never even touched one. But I've been looking at some ads for chassis minus engine and transmission, and the ball end of the wishbone is hanging at least 6 in below installed position. I'm thinking you might not even have to "pull" it down.
    jebbesen and twostickmutt like this.
  11. clem
    clem
    if the only reason to split the wishbones is to avoid dropping the pan once a year or so, I would recommend leaving the wishbones stock, - handling will still be okay, no engineering to be done on a finished car.
    Personal choice though, - obviously.
    Hnstray, bct, alanp561 and 5 others like this.
  12. mkubacak
    mkubacak
    And you don't have to pull the pan on a manual transmission. That is what I would change.
    rpm56, '34 Ratrod, alanp561 and 2 others like this.
  13. twostickmutt
    twostickmutt
    thank you dooley
  14. Dooley
    Dooley
    from Buffalo NY
    My wishbone is hitting the pan and I'm tried of the transmission leaks. 20210405_122547.jpg 20210405_122540.jpg 20210405_122547.jpg 20210405_122540.jpg
    Hnstray, clem and twostickmutt like this.
  15. twostickmutt
    twostickmutt
    me too
    clem likes this.
  16. Dooley
    Dooley
    from Buffalo NY
    twostickmutt likes this.
  17. Dooley
    Dooley
    from Buffalo NY
    New pan installed and bracket lined up to show how it will clear the pan 20210407_143213.jpg
    48fordnut, Hnstray, akoutlaw and 4 others like this.
  18. twostickmutt
    twostickmutt
    100 % better dooley......thanks for the pics !
  19. clem
    clem
    Dooley,
    That looks an easy (or should I say - easier than I imagined) solution.
    Thanks for showing the photos of your progress.
    I split my wishbones and used the same rod ends, and the lock nuts come loose. - I would like to know how you get on with yours. Thanks.
  20. Dooley
    Dooley
    from Buffalo NY
    So drilled the remaining holes in the frame for the bracket.
    So now I need to cut the end of the ball off per the instructions and spread them with the bracket as a guide. Hopefully this weekend. Then I’ll remove the spring down to the main leaf to use as guide to square the perches to ensure proper shackle alignment and get the bungs welded on. More photos to come.
    Hnstray, olscrounger and twostickmutt like this.
  21. Dooley
    Dooley
    from Buffalo NY
    Getting closer
    Hnstray and twostickmutt like this.
  22. twostickmutt
    twostickmutt
    Nice
  23. 1940Willys
    1940Willys
  24. Dooley
    Dooley
    from Buffalo NY
    twostickmutt and Hnstray like this.
  25. twostickmutt
    twostickmutt
  26. clem
    clem
    @Dooley ,
    Thanks for coming back to post your progress.
    I would still be interested to know if your lock nuts come loose ?
    I was thinking of using locktite on mine, although that’s not really the correct thing to do.
    Possibly a spring washer ?
    As the wishbone twists it must loosen the locknuts is what I am thinking.
    Atwater Mike likes this.
  27. Budget36
    Budget36
    Maybe drill them for a cotter key and use a castle nut? Or drill the nut , tighten it, then drill through the bolt using the nut as a guide.
  28. clem
    clem
    Okay, let’s totally hi-jack this thread............:)
    I would also like to know if others have had a similar problem.
    Budget36 likes this.
  29. Budget36
    Budget36
    At least after the hijack it’s still related to the OPs topic;)
    clem likes this.
  30. fordcoupeguy
    fordcoupeguy
    The wishbone arms will twist slightly with this setup. May also affect handling. I never split the wishbones. Just drop the ball an inch and your good to go.Just my opinion.
    cvstl and Hnstray like this.
