Technical Balancer repair sleeve
Discussion in 'The Hokey Ass Message Board' started by sproadster30, Oct 12, 2017.
  1. sproadster30
    sproadster30
    from Natick, Ma
    Anyone used one of those balancer/damper repair sleeves? I've got a couple of balancers, but the surface is kind of worn where the seal rides. Not sure if the sleeves actually work. or are just a"snake oil" thing?
  2. olscrounger
    olscrounger
    work fine--just install carefully--have installed many
    lothiandon1940 likes this.
  3. oldolds
    oldolds
    ^^^^^What he said^^^^^
  4. AngleDrive
    AngleDrive
    from Florida
    X3, they work great and some come with installation tool. Be super careful, they are thin and bend easily.
  5. I've used them, never heard back though so I guess it works
  6. 302GMC
    302GMC
    from Idaho
    Used them since '68 ... everyone has their own favorite installation tricks, I like using a press so it starts straight, and a sealer thinly applied.
  7. Black Panther
    Black Panther
    from SoCal
    Had one put on recently by Groucho on my Tbirds 312...worked like a charm
    ..wouldnt hesitate to use another one..
  8. sproadster30
    sproadster30
    from Natick, Ma
    Great news guys! Thanks! I'll order some up!
  9. They work fine. You don't need a press if you don't have one handy . Just heat the sleeve up a bit on your drop light.
    Put the lock tite on the hub, and just set the hub on the floor .Place the sleeve on straight as you can , set a short 2x4 across it, and just lean on it hard. It should go right on.
  10. sproadster30
    sproadster30
    from Natick, Ma
    I have a press so shouldn't be a problem. Thanks again.
