I need a new harmonic balancer on a mild (300hp) 350. What do you recommend. Fluidampener? Stock oem? Thanks
I'd use a 327/365 or 302/290 one myself... They're both the same and they check out at 8.00" dia. X 2.00" thick.. It's not easy finding those..
I don't think it matters all that much. I tend to use what I have on hand, usually an 8", which was pretty common on trucks and hipo cars.
Just make sure your timing tab lines up with the balancer. At some point GM moved the mark and I always double check it with a piston stop.
