Projects Bad Banana Resurrection - 55 Chevy Gasser
Discussion in 'The Hokey Ass Message Board' started by Bad Banana, Aug 10, 2010.
  1. Lucky3
    Lucky3
    Very cool car and a touching story !
    Go man go !!!
    :D:D:D
  2. 29ToyA
    29ToyA
    Great story! I like all old photos, damn cool project!
  3. biscaynes
    biscaynes
    x2! :)
  4. Wesley
    Wesley
    subscribed, your story is inspiring. I need to be more assertive on getting my dad to the track with me. Our car doesn't have the history that yours does, ours was a father son build in the mid nineties, and I cherish the times we spent together running the car together.
  5. Bad Banana
    Bad Banana
    from Texas
    Time for some update pics. Looking pretty complete under the hood. Need to finish the rad hoses and plumb the fuel system. I am building the rear axle this weekend. Should have it ready to go under the car very soon. Here are some quick pics.
    Step-son helped me make these shock mounts. We used the original holes in the frame and he learned about how to "swiss cheese"
    The rad mounts on the side of the rad with the rubber are original as well as the 3/8" aluminum rod in the front. I moved the rad up a bit higher so I had to raise this mount. I added the upright and gusset and the rear rod to mount the surge tank. The rad is also the last rad in the car from the last time it ran. The surge tank was never on the car. Dad had a fill cap in the top rad hose. I don't have that any more but decided to use the tank he never got around to using. Both are 1965 Vette pieces. You can also see what I did for the throttle linkage (swiss cheesed bracket as well) :D
    Step-son has been working on the brackets for the water pump drive. As I said before, the pulleys are original.
    I think it is starting to look like a racer again! :D
    I mounted up one rear tire and stuck it under there to see what it will look like. Hope to post more pics (both old and new) soon. Right now, I feel I am still on track to be ready to test before the snow melts. :)
    catdad49 likes this.
  6. pregrid
    pregrid
    Subscribed. what a wonderful thread. Here's some Heap Good MOJO for you and your dad.
    Dave
  7. Falcon Gasser
    Falcon Gasser
    Rusty, its coming together really nice, I think you will have no problem to test before the snow is gone as cold as it has been. Whats the next big step?
    Jon
  8. Bad Banana
    Bad Banana
    from Texas
    Putting the rear axle under it and setting it on the ground. After that, I will probably work on getting the engine fired up in the car. It looks like a may have an opportunity to run the engine on a dyno. The guy who owns the engine is buying a used engine dyno local to me. He wants to see an engine run on the dyno before he buys it and called me and wants to use this engine for the test. It is win/win for all of us. I want to make sure there aren't any leaks and I would like to get it to idle so we aren't screwing around with it in his shop. Time will be limited but if there aren't any issues, we can do some tuning on it while it is there. It will make it nicer when I put it back in the car and take it out for the first time this spring. Right now, it will probably not be before sometime in February before we can get to the dyno. Hopefully, I'll be ready when they are.
    Not a huge deal if we can't get to use this engine for the test, but I would like to try. The timing of everything my not work out. We'll see.. ;)
  9. Bad Banana
    Bad Banana
    from Texas
    Check that off the list. I wanted to sweep the floor today and clean up so I pushed it outside. Took some pics outside and then had a hell of a time pushing it back into the shop by myself because the driveway is slippery. No one else home today. Not to worry, I got a running start and it rolled right back in. I think it was starting to shiver a bit.... :D
    Still need to do some rear suspension work but it is getting closer every day.:)
    5.13 gear, spool and Moser axles reside in here now.
  10. alterbob
    alterbob
    from Butler,Pa.
    Looks Good Rusty Lets us know what it dyno's at. Bob Bauer
  11. Bad Banana
    Bad Banana
    from Texas
    Hmmmm maybe... I might just keep that a secret for a while... ;)
  12. Rich1028
    Rich1028
    looking good!
    thanks for the updates.
  13. treeserv
    treeserv
    from n.j.
    :DYour getting there keep it up.
  14. novabbc
    novabbc
    Excellent! Keep up the good work and hope to see you @ Beaver Springs. Here is a couple of pics of mine from back in the day and from the day I picked it up after being stored for 37 years.
  15. uwonamos
    uwonamos
    from Omaha, Ne
    There are no secrets on the H.A.M.B.:D
  16. Just read this thread beginning to end. Awesome.
    Would be great to have a youtube vid on the first drive with your dad there!
  17. Bad Banana
    Bad Banana
    from Texas
    It now runs!!! I had an issue with the injection though. When I cleaned up the barrel valve I noticed there was a light spring behind the idle return fitting and it looked like there should be a jet or something in there. The spring did not do anything. I have not run one of these before but it was supposed to be a running outfit already set up for alky. So... I put it back together as it was.
    As you will see in the video, it was dead lean at idle and really wouldn't start and run unless you bottle fed it. Once I figured it out, there was no place to get any parts. So, I made a small metering disc to give it idle fuel pressure and it was enough to make it run. It obviously needs some tuning yet and I need to locate the correct idle meter disc but I was able to run it enough to get it up to temperature and hear it run for the first time in almost 29 years.
    Step-son was pretty happy to hear it fire. You can see his reaction when it first catches for the very first time. ;)
    Here is the video. To see all of them in order, click on the first one on the left and they should all play. Be advised.... the guy talking (err... ramblin') might have breathed a few too many alky fumes ...especially at the end... :D
    http://www.youtube.com/user/badbanana1955chevy#grid/user/15DC5AE8E1047412
  18. cooljunk
    cooljunk
    Great to hear it fire up at last. You going to be runnin alcohol?
  19. GaryB
    GaryB
    from Reno,nv
    gotta love a injected sbc
  20. ahgarageohio
    ahgarageohio
    from ohio
  21. Badhabit
    Badhabit
    Man, sounds great! I need to go work on my car!
  22. pregrid
    pregrid
    Now THAT'S cool. Good job!
  23. 57rustbucket
    57rustbucket
    from Latrobe
    I live very close to Pittsburgh raceway park. (old keystone raceway) I am in the process of building a 1956 chevy gasser to race there. If you ever come this way PM me on the forum so we can hook up and meet. I am hoping in a year to have my 56 gasser finished and at the strip.
  24. OahuEli
    OahuEli
    from Hawaii
    Music to my ears! Great job and looking forward to the video of it running the 1/4 mile!
  25. Finelinefab
    Finelinefab
    from La salle
  26. Hollywood-East
    Hollywood-East
    Outstanding!!!! Hell Ya!!!! Way ta Go Bro. , Great job on the thread also, Great pics.... Cheers
  27. Bad Banana
    Bad Banana
    from Texas
    Yep... Besides nitro what other kind of fuel is there??? :confused:
    x2
    yup!
    Get to it man!.. it ain't gonna build itself!! :D
    It is cool isn't it.. Thank you
    Will try to rememeber to. Although I have noticed I don't remember as much as I should as often as I should the older I get.. just ask my wife! ;):D
    You and about a bizillion other people it seems...
    Thanks again
    :D
    I have a few more things I need to fab up while the engine is still in the car. Once those are done, the engine and trans comes back out and I need to get crackin' on the body. I figure I really only have about 2 months until the snow melts and I have a lot to do yet. It has taken me about 6 months to get this far and I think I am seeing the light at the end of the tunnel.
    I made some phone calls yesterday and let a few people hear ir run over the phone. My Dad was first obviously. He giggled and I asked him if he thinks it will run at least 11.30s (which is the fastest he ever ran it) and he said "you're worried it might not aren't ya?"... LOL. Then he started pointing out that it now has a much bigger engine, on alky, roller cam, aluminum heads, yada yada yada.... LMAO
    Next was my life long friend Denny who donated the engine and injection manifold to this project. I was on the phone to him when I couldn't get it started and I told him about the barrel valve. We discussed what could be done and I told him what I thought I could do (make a metering disc and use the existing spring) and he felt it was worth a try. Once I got it running I called his shop and he was gone for the day so I just waited for his answering machine to pic up and then fired it up. I'm sure he will get the message... ;):D
  28. koolkemp
    koolkemp
  29. hotrod_32
    hotrod_32
  30. redlinetoys
    redlinetoys
    from Midwest
    Yowie! That thing sounds sweet.
