Hot Rods Back up light ideas
Discussion in 'The Hokey Ass Message Board' started by bob giles, Jul 6, 2011.
  1. bob giles
    bob giles
    I order to comply with the title requirements for Pennsylvania, I need to have back up lights. Who has a idea?
  2. mr.chevrolet
    mr.chevrolet
    i dont have back-up lights. doesnt seem to be a problem in Washington Co.
  3. czuch
    czuch
    from vail az
    They have little auxilary headlights that work great.
  4. anteek
    anteek
    Get some 24v aircraft landing lights. Put in 2 extra batteries wired thru a relay and melt plastic grills on tailgaters. has worked for years.
  5. grovedawg
    grovedawg
    from Heber, UT
    Man that SUCKS! More regulations everyday! And there really isn't anywhere to hide them inconspicuously is there?
  6. Mike51Merc
    Mike51Merc
    No reverse lights on my car here in Pa and nobody ever asked. With Antique and Classic Plates you only need to comply with year-of-manufacture equipment.
    Unless, perhaps you're going for Street Rod plates for a home-built vehicle and they're holding you to the standards for the year of the engine.
  7. grovedawg
    grovedawg
    from Heber, UT
    As much as I hate it can you run some small LED's around the license plate. Hide them as much as possible but still pass inspection?
  8. jcmarz
    jcmarz
    from Chino, Ca
    More "Big Brother"
  9. plym_46
    plym_46
    from central NY
    How can Pa mandate retrofiting equipment not there at the time the vehicle was manufacured??? Do they make old mopars change over from their single trunk mounted stop light?? They are worried about reversing lights that weren't generally available till the mid 50's but they don't care about the lack of windshield wipers???
    Go retro and mount a couple clearence lights to your lower shock mounts and a toggle switch on your shifter.....
    Or mount a strip of led's on your tailgate and then remove them after the paper work is done.
    From Penn Dot
    INSPECTION
    Classic vehicles are subject to an annual vehicle safety inspection. Antique vehicles operated exclusively
    between sunrise and sunset are exempt from the normal lighting requirements of the Pennsylvania Vehicle
    Code, but must have their original lighting equipment. Antique vehicles are not subject to the annual vehicle
    safety inspection. Antique and classic vehicles are not subject to emissions inspection
  10. Mayor of G-Vegas
    Mayor of G-Vegas
    They make tag bolts with lil led lights in them . Get a white set and put them on a switch
  11. I installed small oval shaped driving lights for backups.Kit came with fuse,relay and wires.$29 I think.We have Princess Auto up here,but maybe a surplus store may have them.Auto parts store too,but most likely more money
  12. 49ratfink
    49ratfink
    get on ebay and find some GM backup lights from the 40's. they are in little chrome bullets with a cool lens. some came with a little chrome stand as well. Chevrolet used them up til 1950. in 51 they were just the lens and a chrome bezel, which might look OK on your rolled pan.
  13. rainh8r
    rainh8r
    I like the GM backup lights from the 40's through early 50's. Bullet shaped chrome housing with their own base, rigged on a switch, glass lens, looks right.
  14. 49ratfink
    49ratfink
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Tell em you only go forward in your hot rod..unless its to back over a beaurocrat, and run back over him again:eek:
    hell my 53 didnt even come with them as functioning equipment..it was an option
    add on shit is such a drag, and looks so much like an after thought..sorry they are bing so dickey
  16. TheTrailerGuy
    TheTrailerGuy
  17. evol55
    evol55
    I don't have back up lights and I'm in Pa. I was told by the inspector that if it was not on the car as standard and only an option then you don't need it for the year of the car.
  18. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    WalMart has those chrome bullets cheap. They look OK.
  19. d2_willys
    d2_willys
    from Kansas
    Get those cheapo 2 for $3 LED flashlights and hang them out there. Wire up a switch and you are in business. They will probably say they are tooooo bright!
  20. chopperfugger
    chopperfugger
    from austin
    Is reverse gear required?
  21. grovedawg
    grovedawg
    from Heber, UT
    Best idea yet. Do the least amount of work/cost to pass inspection and rip that crap off as soon as you're papered.
  22. 48 Chubby
    48 Chubby
    Go buy two of the cheapest lights you can find, hang a couple wires and a switch to the battery. Then go get your paper work, drive home and take that crap off.
    Just what I would do.
  23. 48 Chubby
    48 Chubby
    Go buy the cheapest lights you can find, clamp them on, run a couple of wires through a switch to the battery. Go get your paper work straight, then drive home and take that crap off.
    What I would do any way.
  24. brad chevy
    brad chevy
    To everybody saying he does"nt need them because of the year it is,well anybody including an inspector can see this is not a stock,original vehicle so he does have to follow the state guidelines. Go down to your nearest motorcycle shop and pick up a couple of the small,not L.E.D. driving lights and mount them up underneath where you want and be done with it. The lights are about the size of a half dollar.
  25. Any truck stops near by? Go into the chrome shop, there you will find your choice of hundreds of lights, should be able to find one to your likings. :D TR
  26. HOTFR8
    HOTFR8
    Not very clear in this photo but you can see the reverse lights I used on my T Roadster. I just looked round to see what I could find and these are similar to a Ford Escort from about 1970's and fitted in nicely with the tail lights I used. If you look hard enough you will also see a 3rd brake light hidden under the roll bar.
    Some of the aftermarket LED's look good and could be hidden so as not to obvious.
  27. rancid737
    rancid737
    how about this lenz in this type of housing plus a beauty ring? always thought it would make a good tail light assy.....
  28. bob giles
    bob giles
    Thanks for the suggestions. This is what I came up with. $13 for TRUCK LITE lights.
