B Engine Water Inlet Location
Discussion in 'The Hokey Ass Message Board' started by colinsmithson, Feb 5, 2013.
  1. colinsmithson
    colinsmithson
    I have what I belive is a Model B engine Only the Water inlet is more to the rear of the block than normal is this a mod or just odd ford engine
    I have checked other B models and they are all in the center of the block
    hope tou can help colin
  2. Carter
    Carter
    Easiest way to tell a model a block from model b is fuel pump boss at lower front passenger side of block on the 'B'.
    Have any pictures?
    Sent from my DROID device using the TJJ mobile app
  3. Bruce Lancaster
    Bruce Lancaster
    Can you get pictures of both sides of the block? I don't think this will turn out to be B, but who knows. I've never seen an A or B block with inlet anywhere but center.
  4. I have been into Model B engines for several years but have never heard of anything like you describe. I would tend to think it is not a Model B engine. As Bruce said, pictures would resolve the question quickly.
    Charlie Stephens
